Check out my welds (4th day)
Old Sep 17, 2011 | 01:46 PM
b16bri's Avatar
Default Check out my welds (4th day)
Wanted to show you guys/ get some input on my welds. I bought my first Tig machine (diversion 165) a week ago. Been welding for about 4 days. Check them out.
Old Sep 17, 2011 | 01:49 PM
b16bri's Avatar
Default Re: Check out my welds (4th day)
And heres the back side of the welds. I forgot to mention this is on .090" Aluminum. Which i think is 11 guage not sure tho.
Old Sep 17, 2011 | 06:55 PM
Chops13's Avatar
You don't want burn thru. Either you're going too slow or you're using too much heat.
Old Sep 17, 2011 | 08:24 PM
TrackMasters_AZ's Avatar
Your speed looks ok, but practice more on the heat than the look of the weld... What really helped me was the angle of the torch and pedal control. N E Way you will get better with repetition and patience LOL
Old Sep 17, 2011 | 08:51 PM
b16bri's Avatar
Ok what would you set the amps on ? it's .090 thickness. I know I have got a lot to learn and practice but how do you think they look. Foe only welding 4 times
Old Sep 17, 2011 | 09:00 PM
b16bri's Avatar
Im a little confused about the burn threw arent the welds suspost to penatrate threw to the back side or not with aluminum ?
Old Sep 17, 2011 | 09:40 PM
RadekSkylark's Avatar
I would suggest starting out with mild steel... can't understand why everyone who has a welder which works on AC starts with aluminium... it's much more difficult then mild steel. I would suggest get 1/8" and 3/32" mild steel plates, start out with them, when your ok, go to stainless steel, and only then aluminium. At least that how I would do it if I would have and AC welder...
Good luck
Old Sep 17, 2011 | 09:53 PM
Good luck
I agree, aluminum burns fast and is hard to practice with if you are a noob..
Old Sep 18, 2011 | 07:04 AM
b16bri's Avatar
Unfortunatly I have a bunch of aluminum here that I figured I would learn on and it would get it out of my house. Kind of a win win lol. Any advise on the aluminum welds what i'm doing right or wrong for that matter
Old Sep 18, 2011 | 07:39 AM
TannerS14's Avatar
I started with aluminum and i think it helps to be honest. With steel you dont get a feel for heat. If you're too hot with steel it turns gray and looks poopy. If you're too hot with aluminum you burn through. So it teaches heat control really well. Lookin good.
Old Sep 18, 2011 | 10:38 AM
b16bri's Avatar
The burn threw everyone talks about arent i suspot to have peneration on the back side ?
Old Sep 18, 2011 | 03:08 PM
Chops13's Avatar
No. Burn thru is over penetration. You should never have it. The only thing you should see on that side of the metal is discoloring from the heat. Just turn down your heat and keep practicing.
Old Sep 18, 2011 | 06:14 PM
b16bri's Avatar
Ok, thanks. I'm obviously real new to welding. I'm confused though because I've seen pictures on here and real life stuff such as manifolds, exhausts, IC piping, where if you look inside the pipe or the manifold, you can see the welds especially on a stainless manifold you can see them inside on the back side of the weld. Is that different than aluminum? Thanks again for all your help. I'm just starting out trying to learn and make sure I learn correctly
Old Sep 19, 2011 | 12:41 AM
CO_RaceFab's Avatar
start with steel aluminum will follow
Old Sep 21, 2011 | 11:47 AM
SpeedwayCoating's Avatar
Yeah you diffidently have to much heat, but honestly for it to be 4 days worth of practice I would say it is alright. Start trying to weld joints butt welds and t joints will teach you a lot.
Old Sep 21, 2011 | 01:08 PM
FabChild's Avatar
Aluminum is perfectly fine to start out on, it's all about torch time. Some weldments require 100% penetration and other do not. When your welding on a flat plate you want it to penetrate but not burn all the way through. Hope that helps.
Old Sep 21, 2011 | 03:31 PM
b16bri's Avatar
ya it's only my 4th day I will turn the heat down and take some more pics. I actually welded a bunch that neverd burned threw and I thought I was wrong becuase I saw no penertration. lol I will turn the heat down and try again. I wanna start welding peices together i have to get some more aluminum. Thanks for all the help. Keep an eye out for some more pics.
Old Sep 21, 2011 | 03:37 PM
ACKPerformance's Avatar
Agreed, starting out with aluminum is fine. I did, And I also agree theres to much heat, but they look decent for only 4 days. keep it up it will come.
Old Sep 21, 2011 | 06:56 PM
SovXietday's Avatar
I started out on AL too. Actually had a hell of a time adjusting to steel until I figured it all out.
Do yourself a favor and start cutting all of that aluminum up and start making T joints and practice welding pieces together. You will learn a lot more about heat control this way than doing it on plate.
It's all about torch time now and trying out different things.
b16bri
Welding / Fabrication
15
Dec 23, 2011 07:28 PM
SlicksMH
Audio / Security / Video
13
Aug 12, 2009 09:14 PM
champLSinteg
18
Sep 11, 2008 07:34 AM
Willybeen
Honda Motorcycles
12
May 27, 2005 04:00 AM
JM Performance
Dec 30, 2003 10:02 PM
