NEED HELPP
Old Sep 17, 2011 | 12:10 PM
cec12789's Avatar
Default NEED HELPP
I recently got a 95 integra... it has a rebuilt motor it had hondata s300 but the seller wanted to keep that with the sale so i got the stock ecu a obd1 p75 ecu and just connected it up. When I start the car it takes a minute to start... once started it idles very low and if you give it gas it bogs. There is a check engine light on in my dash. Once the car is warm it drives normal but the check engine light it still on... anyone have any ideas what it could be.... I saw this was cut when i put the ecu back on... idk if this has anything to do with it or not? anyone know what the wire is to.. its blue with black stripe.. thanks
Old Sep 17, 2011 | 12:33 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: NEED HELPP
Looks like A4 where they would have had the VTEC wired up but that probably wouldn't make it run weird. Pull the CEL and see what it is.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Sep 17, 2011 | 12:47 PM
cec12789's Avatar
yeah the car once had vtec now it does not tho
Old Sep 17, 2011 | 09:59 PM
mouab18c1's Avatar
The ls ecu won't even be looking for Vtec. You need to figure out what the CEL is for. There is a DIY in the Integra Faq that will show you how to do it. Once you find out what the code is then go from there.
Old Sep 18, 2011 | 06:39 AM
cec12789's Avatar
Ok i did the self test it came up as number 6 the water temp sensor...now what should i do... can i drive the car like this or ? how do i go about fixing it?
Old Sep 18, 2011 | 08:02 AM
GagnarTheUnruly's Avatar
You've either got an open in the wires connecting the ECT sensor to the ECU, or you've got a faulty ECT sensor. You could try replacing the ECT sensor. I've got a troubleshooting guide in my Helms but it doesn't tell what the proper voltages should be when it's operating correctly.
Old Sep 18, 2011 | 09:59 AM
mouab18c1's Avatar
If you have a volt meter, the wire should read 12+V.
Which pin is that loose wire coming out of? A bad ECT sensor will make your car run like crap. Fix it!
Old Sep 18, 2011 | 10:42 AM
Technical Hero
Old Sep 18, 2011 | 11:15 AM
^^ damn that flow chart is way better than the one I have...
Old Sep 18, 2011 | 12:36 PM
cec12789's Avatar
do i just the volt meter in the connector? what should all the wires read?
Old Sep 19, 2011 | 07:08 AM
cec12789's Avatar
still need help... so i had a bad wire on the ECT sensor i fixed that started the car and it idled good now but the check engine light is still on... i tried doing a self diagonstic again but when i did and turn the ignition on the light just stayed there no flashing or anything like that so do i just need to get it reset or something?
Old Sep 19, 2011 | 05:20 PM
AZITRCLONE's Avatar
You can reset the CEL yourself. Dont pay anyone to do that. Google is also a great tool.
Old Sep 20, 2011 | 09:38 PM
mouab18c1's Avatar
Just disconnect your battery for 15 secs.
Old Sep 21, 2011 | 05:34 AM
cec12789's Avatar
i tried that it did not work, i also tried removing the fuses for a few min that didnt work then i tried removing the ecu for a min and that did not work
Old Sep 21, 2011 | 07:23 AM
mouab18c1's Avatar
So now you have a solid CEL? In that case you have a faulty ECU.
Old Sep 21, 2011 | 12:55 PM
cec12789's Avatar
huh?... the car runs fine and it showed me the flashes.. then i fixed the problem so now there are no flashes but i tired to manually reset the cel so it gets off my dash and it wont work..
Old Sep 21, 2011 | 04:27 PM
mouab18c1's Avatar
Exactly now you have a Solid CEL that won't go away after resetting it right?
Old Sep 22, 2011 | 05:53 AM
cec12789's Avatar
yeah but if the ecu was faulty wouldnt it not work properly when the car runs ? the ecu came out of a perfectly fine integra with no CEL on
Old Sep 22, 2011 | 10:58 AM
mouab18c1's Avatar
No need for two threads. If you don't want to verify if the ecu is faulty or not then enjoy running in circles.
B20_SI_CRX
Jun 3, 2005 09:03 PM
Jdm_Honda_Integra
Oct 25, 2004 06:59 PM
jbscivichb92
Sep 1, 2004 04:54 AM
Luserkid
18
Mar 8, 2004 07:24 PM
Metal_SOL
Jul 16, 2002 10:23 PM
