water in the trunk of ep3
Old Sep 16, 2011 | 05:49 PM
b17itr's Avatar
Default water in the trunk of ep3
was cleaning out the ride and saw my trunk was wet. anybody ever have this problem- not sure if its coming from trunk seal or sunroof seal..
Old Sep 20, 2011 | 07:06 AM
slate13530's Avatar
Default Re: water in the trunk of ep3
Check to make sure where the water is suppose to run off isn't blocked
Old Sep 20, 2011 | 08:21 PM
rjmq06's Avatar
mine too when i was cleaning my trunk i notice the carpet is wet but i never try to look for the problem i just put a cloth in there
Old Sep 21, 2011 | 07:56 AM
<StevieG>'s Avatar
I had water come in my right rear strut...
Old Sep 21, 2011 | 06:52 PM
b17itr's Avatar
did water test- sunroof drains are good will try tailights and trunklid. i'll check my rear struts this wekend thanks guyss...
Old Sep 27, 2011 | 11:21 AM
unomystz's Avatar
I have water gettting in my ep as well, and i found it was coming from the holes used to mount the wing to the hatch.
Old Oct 4, 2011 | 12:13 AM
99preludeowner's Avatar
check if you have same issue with 5th gen prelude because they mostly have leak on tail light gasket
Old Oct 4, 2011 | 12:23 PM
PittsburghNBP's Avatar
I always get water in my spare tire well of my rsx. its because of my tail light gaskets though. one of the annoying problems with rsx's. not sure if that could be your reason though. try taking out your tail lights and check just incase.
Old Oct 5, 2011 | 04:58 PM
b17itr's Avatar
update on trunk leak coming from trunk seal and taillight seals- no more leaks
Farquea
Nov 9, 2018 05:00 AM
x1aO
Mar 10, 2008 01:02 PM
Wiseguy619
Nov 11, 2006 03:49 PM
effinnwackk
10
Jul 15, 2005 05:31 AM
.ShawnD.
Apr 26, 2004 10:33 AM
