01 integra gsr sputtered now wont start bone stock
any ideas bone stock integra started siputting during exeleration and check engine flashing so i went to auto zone and check the capi and rotor / plugs .
plugs where fine. rotor and capi where a little burnt so i replaced them now i go to start the car and it just cranks FML..
thinking bad gas or ignision coil any ideas
by the time the tow truck driver came it was dark
long story short, if you ever crank the car with a spark plug wire off, or are driving and have the rotor come off and only make partial contact or.. many more situations it fries the coil. autozone cheapies are like $25 and they work for quite awhile
auto-zone wanted 80 bucks for the coil and 319 for a remanufactured distributor so i said if im gunna pay that much its gunna be oem so i got one from the dealer in a day.
so i put it in and the car runs again witch is great but it sputters still so i knew it had to ignision resoning so i just picked up a set of plug wires and boom no problem it seems the number 2 cyclinder wire was actually frayed a bit from heat i guess witch inturn killed the coil from grounding out.
your situation makes sense though. these coils are so easy to fry. keep this in mind if you ever do a compression test.
quad
20
Mar 14, 2007 05:16 AM
