Honda S2000 Honda S2000
Should I use this replacement CV axle?
Old Sep 16, 2011 | 04:14 PM
usafstud's Avatar
Default Should I use this replacement CV axle?
I'm in the process of swapping my CV axle since the threads at the ends got cross threaded during removal when I just trying to retorque it to 220 ft-lbs. Anyways, napa-autozone-o'reilly didn't have CV axles so I had to get a new one online for $90 at http://www.autopartswarehouse.com/de...3-1714672.html
Anyways, on closer inspection, I noticed that the axle itself is smaller in diameter and the rubber boot clips don't look as well designed to stay together. You guys think this could be a problem? I'm wondering if I can move the oem boot clip from the old one to the new axle?
Old Sep 17, 2011 | 04:18 AM
Boots's Avatar
Default Re: Should I use this replacement CV axle?
its probably a redesign...check the parts numbers to see if they match up, should be fine
lerks909
Jul 25, 2014 10:25 AM
DC2SIR-G
Feb 26, 2006 06:13 PM
david90
Jun 19, 2004 03:30 PM
magic hat #9
Feb 25, 2004 06:23 AM
