ABS warning light on all the time.
Old Sep 16, 2011 | 02:32 PM
UK Texan's Avatar
Default ABS warning light on all the time.
96, Accord suddenly started showing the ABS warning light. It started after considerable work on the brakes. Nothing was done to the ABS unit, but I'm not sure if it was topped up. Does it take the same Dot 4 that the rest of the system uses? i.e. is there a separate fluid route to open the valves?
Any typical faults that give the warning light?
Great care was taken with the work and no recollection of brake sensor units being dislodged at any time.
Low mileage. Little or no rust. Need to get some more life out of it. Any help would be appreciated.
Old Sep 16, 2011 | 06:54 PM
Lost Again's Avatar
Default Re: ABS warning light on all the time.
4 or 6 cyl?
Either way, get the codes. I'm going to guess one of the sensors got damaged. The codes will tell the story.
krazyk606
Jun 15, 2009 07:32 AM
EXccord
Sep 14, 2006 06:29 PM
FLATOUTRACING
Dec 11, 2005 03:06 PM
Accord2k-Hybrid
Oct 27, 2005 09:41 AM
MF-DIF
Feb 11, 2004 05:35 PM
