FS:1995 honda civic ex 2dr (auto)
i have a bone stock 1995 honda civic ex auto. 180,xxx miles. i have replace the following:
-timing belt and tensioner
-water pump
-headgasket
-intake manifold gasket
-throttle body gasket
-radiator
-valve cover gasket
-new battery
i commute with this car to school and work. took the motor out because i was planning on swapping the motor out but changed my mind and installed the original motor back. all the power window, locks, and sunroof works. the only thing thats bad is rust on the rear corner panel, the fender and front bumper need to be painted and a dent on the driver side door.the belts are squeaking and upper ball joint needs to be replace. asking $1600 OBO. you can text me at 815-978-8963.
-water pump
-headgasket
-radiator
-valve cover gasket
-new battery
glws.
