Tuned p28 for boost on d15b7?
Alright guys quick question..I know you can run a non-vtec d15 on a p28 ecu and it will work, but throw a code for vtec since it is not wired so here is my question....
my friend had a boosted z6 with a t25 on it, he had it tuned and ended up parting the car out..now I can pick up the ecu cheap, so would this work on my d15b7 if I ran his set up..same injectors, fuel pump t25 ect and have no issues with my b7? would it run rich?
I wonder because I would think the p28 would have a little different fuel graph since a z6 has a bigger IM and TB so it sucks more air..but I could just be an idiot here..
Thanks for the help
Thanks for the help
you say hes p28 is tuned? if its chipped have someone disable the vtec options on the chip and use his ECU/CHIP with the matching setup its tuned for.
it would prob be closer if u ran a z6 head but u would still need a tune. all cars preform differently even from the factory. most honda's and acura's are naturally aspirated and the stock basemap all run off of is pretty close. when boosting many things can be a factor even ur displacement differences and ignition timing could blow it up or cause harm to the engine.
