Suspension & Brakes Theory, alignment, spring rates....
quick ?
Old Sep 15, 2011 | 05:37 AM
ryanplayjoint's Avatar
Default quick ?
i have a 96 hatch and i'm attempting to put a itr rear sway bar on. my question is will the brackets that mount to the rear subframe fit the itr sway bar? I do have the correct "D" brackets for the sway bar just wanted to make sure the other side of the mounting bracket will work. thankyou
Old Sep 15, 2011 | 08:11 AM
egsleepercivic's Avatar
Default Re: quick ?
http://hybrid.honda-perf.org/tech/ITRon5G.html this is on an eg, for your 96 I would think you would need some reinforcement for the ITR bar so it doesn't rip the subframe
Old Sep 15, 2011 | 08:21 AM
phunhaus's Avatar
Default Re: quick ?
That's outdated. Make sure you use a reinforcement kit.
Old Sep 20, 2011 | 02:45 PM
Default Re: quick ?
So i got rear links for a 99si but after lookin at the bar im pretty sure i need links for the itr sway, also can i use 99si bushing mounting brackets? The write up in the link is for an eg/dc which if im not wrong has a different rear subframe desgin.
Old Sep 20, 2011 | 04:46 PM
Default Re: quick ?
01 R
https://www.hondapartsunlimited.com/...%20LOWER%20ARM
99 si
looks like they use different endlinks, does the ITR sway line up with holes in the lca's of the civic?
Old Sep 20, 2011 | 04:56 PM
98civdx's Avatar
Master Detailer
Default Re: quick ?
Originally Posted by egsleepercivic
01 R
99 si
endlinks are complety different. But, You should be able to use 99-00 SI rear endlinks without issues. Other than you will need to buy spacers for the endlink side of the sway bar.
Holes are larger then 96-00's.
jonyi27
May 27, 2014 03:53 AM
forcefedferio
Jan 22, 2007 10:37 PM
phatcivic99
Nov 27, 2003 07:03 AM
abolish415
Oct 3, 2003 12:08 PM
Jimmy L
Dec 29, 2001 04:22 PM
