compresion results
Old Oct 4, 2002 | 11:39 AM
supanatural's Avatar
Default compresion results
I did a compression check on my b20 vtec-gsr head
My results 232 230 231 230- I was happy that all the numbers were equal, but I expected a little higher number- I have b20 block- eagle rods, endyn pistons- mid na dome- My gsr head is milled like 55 over, so I have a thicker cometic gasket.
So Im cotemplating taking headgasket off, but since im only running ctr cams right
now, and I alreadly order my toda b's, Im wondering if I should wait untill I tune
the todas to see how much mor power it will make. My first dyno results were
190hp 136ftlbs with ctr cams and jdm itr header hondata stg 2
Just asking some advice of what I should do- wait to get the cams or take headgasket of for more compression which will probably add some more hp.
Old Oct 4, 2002 | 12:06 PM
Spade's Avatar
Default Re: compresion results (2.0literDC2)
WHy were you expecting higher numbers?
Old Oct 4, 2002 | 12:41 PM
Fly By Ya's Avatar
Where did u get your hondata tuning done? did u do it yourself?
[Modified by Fly By Ya, 9:42 PM 10/4/2002]
Old Oct 4, 2002 | 12:52 PM
badCRX's Avatar
New User
Default Re: compresion results (Fly By Ya)
For comparison for ya, I have a B20 with Eagle rods and the high NA dome pistons from Endyn and I got 275 psi across the board. I expected higher too. I have a B16A head. I requested little milling from the machine shops that did my block and the head.
Old Oct 4, 2002 | 01:07 PM
B19CivicHB's Avatar
Default Re: compresion results (badCRX)
wanna sell your CTR cams...?
Old Oct 4, 2002 | 05:30 PM
shadowdawn's Avatar
Default Re: compresion results (B19CivicHB)
Wait a minute you have a b20... and your only making 136lbs of torque? Mabye its just cause I see too many boosted b20's and the sick tq they make that your number suprises me.
B20 Civic
Jan 18, 2008 06:09 AM
ultra efro
Dec 4, 2004 11:41 AM
Propulsion
Dec 9, 2003 10:25 PM
TwistedHatch
19
Oct 25, 2003 11:34 PM
acura_typer
34
Nov 26, 2002 07:35 PM
