b16a2 Tuned Afr ideal.
Old Sep 14, 2011 | 10:36 PM
kanashibari's Avatar
Default b16a2 Tuned Afr ideal.
Hi,
Tuned b16a2 for idle, the VTEC point, red line should be the point?
Old Sep 15, 2011 | 01:29 AM
yungkhmer's Avatar
Default Re: b16a2 Tuned Afr ideal.
did you really have to make more than one post about your stupid question?
vtec point should be set to 6500 RPM's and redline should be set to 12,000 RPM's
Old Sep 15, 2011 | 01:51 AM
wolve's Avatar
don't misinform the poor guy
vtec should be set at idle for max performance and the revlimit at 5000rpm, because most engines go kaboom if the vtec powerband is extended for more then 4000rpm.
OP don't be fooled by what other people try to trick you to do
Old Sep 15, 2011 | 03:17 AM
I do not know much.
If you do not know Do not point wrong.
other topics of the forum reviewed the idle AFR: 14.7 I have read that.
Thank you anyway.
Old Sep 15, 2011 | 03:52 AM
GhostAccord's Avatar
VTEC crossover 5600 - 5900 rpm (depends on where your engine performs best, find the rpm that has smoothest engagement point with no hesitation or big jump)
Rev limit - 8100 rpm
Idle AFR - 14.7 - 15.5
Wide open throttle AFR - 12.75 - 13.5 (also depends on where your engine performs best)
A dyno or good street tune with datalog will be a better way to find where your engine performs at it's best. For both AFR and RPM crossover points.
Old Sep 15, 2011 | 04:10 AM
Thanks for the information you provide.
VTEC point 5900 using current setting.
afr at idle you say you want to set mine up to the poor.
Can you look at the comments in my hand the current output of the dyno?
Old Sep 15, 2011 | 04:30 AM
If poor = leaner, than yes, that is what I am saying. A lean idle is OK, your engine doesn't need 13:1 AFR at idle. It really only needs enough to keep it running. While at the same time keeping it from detonating (going too lean)
If your engine is making power above 8000rpm you would want set your rev limit higher. However, I didn't see anywhere in your build that you have done any work to the valve train or block. You might want it to be around the 8500 rpm range with a stock valve train and rod bolts.
From what I can see your dyno looks pretty smooth. Have you tried different changing the AFR's and timing to see if it will make any difference?
Old Sep 15, 2011 | 04:31 AM
wolve's Avatar
now you ruined it
for real... OP the above is good info!
Old Sep 15, 2011 | 04:56 AM
Here is my vehicle that I modified the list and dyno.
B16a2
Skunk2 Pro Intake
thortle body ctr
Simota Carbon big tube
Mugen 4-1 2.25 "headers
2.5 "ex-pipe 2.5" exhaust apex
exedy stage 2 clutch
apex power fc commander
AEM wideband
1-The first original map with the b16b
2-the original version of a map made ​​with that in multiple 12.5-12.7 afr
between 5500 rpm and 85000 rpm, just fixed it.
Old Sep 16, 2011 | 05:31 AM
Current.
Have different ideas on this?
Old Sep 16, 2011 | 11:50 PM
HdeucedeuceA's Avatar
I have a great idea! How about you pick up a tuning book and read it. Or at least search.
Sorry if I come off being a dick...but seriously
Old Sep 23, 2011 | 03:31 AM
update.
crazyguy
Sep 10, 2007 07:07 AM
iphatcrxi
Sep 13, 2006 10:03 AM
bigbadboy
Jul 6, 2006 09:23 PM
