F/S K24/20 Integra 270whp All Motor
1996 integra
walbro 255lph pump,
aem regulator
bdl fuel rail custom coated
modified type s injectors
innovative mounts
hybrid racing swap harness
k-pro
itr booster
brand new itr master cyl
rs brake lines/40 40 prop valve
abs is deleted
500 miles on 205-50-15 falken 615k's
koni yellow shocks
eibach sportline springs
ssr lca's
rs front seats
faux itr cf interior
leather shift ****
jdm itr pedals
itr rear seats
alpine ipod deck
clock delete
jdm itr cluster
k24a4 block (450 miles on motor, going up daily)
12.5:1 cp pistons (rings spec'd between all motor and nitrous)
blueprint I beam rods
oem bearings
steel k24 pan
k20a2 oil pump
k20a2 head
k20z1 cams
shaved/ported rbc manifold
k20a2 tb
karcepts cold air intake
custom powdercoated valve cover
carbon fiber plug cover
04 type s transmission
brand new 2nd gear assembly
completely checked over in EXCELLENT shape
type r lsd
comp clutch stage 4
r-crew header
magnaflow resonator
3" thermal exhaust
karcepts shift plate
buddy club shifter
oem rsx type s shifter cables
tucked battery
tucked bay harness
stock 02-04 type s engine harness
The car is white, it has 2000 spec front and rear bumpers. It has minimal rust bubbles in the quarter panels. It does have small dings here and there. It could use a good buff job. It runs/drives perfect. Oil is changed every 3 months. Trans fluid has just been changed. It shifts perfectly in and out of all the gears. (no grinds whatsoever) The car makes 270 whp on 93 pump gas. The only thing that limited it was the injectors. Toss some bigger injectors in it and it would be closer to 300whp. Its a low 12 second car with a set of slicks/drag radials. Its a perfect daily driver. I am open to trades, but no junk!!! The worst I can so is no but dont waste my time. I can send pics via email or SMS.
10k or best offer......
Call or text me 815-546-0727 -John
walbro 255lph pump,
aem regulator
innovative mounts
k-pro
itr booster
abs is deleted
koni yellow shocks
ssr lca's
rs front seats
leather shift ****
jdm itr pedals
itr rear seats
alpine ipod deck
clock delete
jdm itr cluster
oem bearings
steel k24 pan
k20a2 oil pump
k20a2 head
k20z1 cams
k20a2 tb
type r lsd
comp clutch stage 4
r-crew header
magnaflow resonator
3" thermal exhaust
buddy club shifter
tucked battery
tucked bay harness
EARLdaSQUIRREL
Mar 21, 2010 10:28 PM
EARLdaSQUIRREL
Mid-Atlantic (Sales)
Mar 19, 2010 10:27 AM
