95 Civic Ex...Project Build 450 whp Goal
Whats up Guys i wanted to show you Guys &Get some Input and Got some Questions Also..So Heres My Most Recent...I Know you guys are like Look at this piece of Sh*t Primer Car...But Hit Deer and didnt want 3 Different Colors So just primerd All Grey...Getting Painted Soon....But my Goal is 450whp Boosted
MY CAR INFO & Mods
1995 Honda Civic Coupe EX...95,000 Orginal Miles on Body
B16A2 LongBlock...51k Miles Before Rebuild..
B18B1 Hydro Tranny 84k
ENGINE MODS
Skunk2 Tuner Series Silver Cam Gears
Skunk2 Tuner Series Stage 1 Cams
Brain Crower Duel Valve Springs
Brain Crower Retainers/Keepers
ARP Head Studs
ARP Rod Bolts
ARP Main Studs
SPEC 12.5lb Billet Aluminum Flywheel
SPEC Stage 4 Pressure Plate
F1 Stage 3 6 Puck Clutch Disc....JUNK UPGRADING
OEM Type-R Oil Pump
Golden Eagle Red Fuel Rail...A/N Fittings
Air Flow Engerneering 6" Filter/Aluminum Volcity Stack(Off a BMW M3)
Custom 3" Intake
Exhaust Manifold Rapped
TSUDO 2.5" Stainless Steel Cat Back Exhaust
TSUDO Stainless High Flow Cat
AutoMeter Air/Fuel Ratio /Oil Pressure 0-100 psi/Boost 0-20 Psi
AutoMeter Grey Triple GauGE Pod
Chipped/Socketed/Datalogged P28 ECU...(Tuned on Chrome)
SUSPENION/WHEELS/RUBBER
Skunk 2 Sport Series Struts/Spring Combo
Skunk 2 Pro Series Front Camber Kit
Skunk 2 Pro-Series Front Strut Bar
8 Pt Roll Cage
CROW Purple 5pt Harness's
Benen Purple Rear Tow Hook
Rear Integra GSR Sway Bar
ADR Sukudo 17x7.5 Wheels
CX Manuel Steering Rack
TURBO KIT
This is what i got to turbo as of right now...Turbo set up is Not on...Wanted to Know How much Whp/Psi I can run Safely on My Current Motor
Iron Top Mount Turbo Manifold...T3&38mm Flanges(Its a Ebay Brand But Other then Having to Port WG&Head Ports Its a Good Manifold for $200 Bucks...Wastegate is In good Spot and Turbos up top
CX Racing 38mm External WasteGate(14.7 Psi Spring)
CX Racing 28x7x2 Front Mount Intercooler
Stealth Mode Oil Feed&Return Line
Skunk 2 76mm (3") Stainless Steel Exhaust...Cut off Resinators/Muffler&Running Stright Pipe to Burns 4" Stainless Steel Turbo Miny Muffler
Chipped P28...Clhrome Dealer Tuning softwARE
3" Custom Down Pipe /w Flex Pipe
Turbo XS RFL Blow Off Valve
Stainless Steel 2 1/2 Charge Piping/Silcone Couplers/T-Clamp
THINGS I NEED
T3 Turbo...5 Bolt Flange...Name Brand...Good Up to 450 Whp
Injectors 750cc Or Bigger
Omni Power 70mm Throttle Body
Tial 38mm Wastegate
???? Things I wanted to Ask ????????
How Much Whp Can i Run on my Current Set up...Safely...
Whats Best Turbo For 400-450 Whp...Dont need Room to Grow
Whats Best Clutch For my Goal
Is 38mm Wastegate Good for 400 whp
Heres Pic
MY CAR INFO & Mods
ENGINE MODS
ARP Head Studs
ARP Rod Bolts
ARP Main Studs
OEM Type-R Oil Pump
Custom 3" Intake
8 Pt Roll Cage
TURBO KIT
THINGS I NEED
Tial 38mm Wastegate
Heres Pic
Ya i kno i have a Fulll stright 3" turbo back to Burns stainless 4" muffler...i got a set of 15's wit m/h slicks...i had a B18b1 turbo 14.7 psi 1 bar Stock block...and it would burn up to 4th wit 15s an 17s
Then you had a traction problem.
I repeat; why are you NOT building the block? Stock B-series blocks are only good for about 300hp.
heres a place to get 3" tubing with new hardware
http://www.vrsexhaust.com/TUBING_KIT.../honda_tk.html
