Swap for 95 odyssey ?
I have a 95 odyssey and the motor feels a little tired. Will the h22 bolt right in? lastly i was thinking the 3.5 v6 from the newer odyssey. Any ideas on the swap would be great. I have looked at Hasport and Inlinepro and cannot find mounts.
Even though i am going to be adding a lot of weight to it. I mean i am going to be bagging it system and a lot of other stuff I was just looking at that for the torque.
So I guess that is what it going to have to happen. So the H23 or H22 is the motor that is going to have to go in. That kinda sucks I wanted to do the J35 but no seem to have any info on it.
So does the H22 or the H23 just drop in or what. I mean what does this swap consist of.
v6 swap can be done but it would have to be a c27 and that would be a downgrade from most h-swaps. J32-35 might fit with cutting and welding but that bay is tight on both sides.
Also, the H-swap will bolt in with just swapping driver mount with a prelude mount but your 95 is obd1 so wiring will be tougher. Original tranny and axles bolt up, need h manifolds,dizzy,ecu.
