HELP 95 gsr start sometimes only
i have a 1995 integra gsr that starts but it will take about 4-9 key turns before it will start...i dont know what is wrong with it..if you guys can give me some info that would be great..also i just bought a new battery..thinking it was the battery..but its not
honestly there could be alot -
starter
ignition switch , lock cylinder could be worn out.
starter relay if the car has one.
bad ground as well could do that. i had bad ground and mine wouldnt start.
what is it doing does it turn over all 4 times just wont fire up
or wont turn over at all n clicks or doesnt do anything?
starter
if it just clicks it could be your starter.... have someone turn and hold the key to the on position and when u hear the click gently smack ur starter a bit and see if it gets going. you can also get it tested for free at autozone but u have to take it off.
Jack Murphy
Jun 21, 2017 06:23 PM
