90-93 Accord half shaft on H22 swap
I was thinking of switching over to this half shaft instead of my current prelude half shaft. That way I can just buy 93 integra axles out of the box and install them with out having to use prelude inners on teg axles every time they blow. Anyone have a preference?
Correct 90-93 Accord half shaft/midshaft and 90-93 Acura Integra Axle for driver side this is what I use on Hybrid swaps. If 90-93 is too long next step is 88-89 Acura Integra 1/2" shorter
Same goes for the Passenger Side 90-93 Acura Integra with Accord Inner Joint or 88-89 Acura Integra with Accord Inner Joint 1/2" Shorter then 90-93.
If ABS 88-89 will require the ABS ring to be added. Since no ABS was available.
I never updated this thread but I did end up switching to the 93 accord half shaft with 89 teg axles(both sides). After I went through all of that my buddy had a H swap and blew out an axle(driver side) and replaced it with a regular b16 axle. Lol so all of that for nothing but worked for him.
tdo
Nov 23, 2005 12:24 PM
patastinky
May 9, 2005 05:43 AM
BIGBLOCKEK
Sep 3, 2004 09:00 PM
OEMJDM
Sep 14, 2002 07:30 PM
