Slammed
Old Oct 4, 2002 | 10:48 AM
Muckman's Avatar
Moderator in Chief
Default Slammed
Ive recently installed Ground Controls and Koni Yellows on my GSR. My goal was performance not looks as I ordered equal spring rates of 400F/400R. Originally I only wanted to drop it 1.8-2". However I ended up falling victum to the ricer side and ended up slamming my car. Its about 2.75" - 3" lower than stock. 1 finger gap all around. When fully loaded with weight the Konis look nearly fully compressed. And Im practically ridding aroud town on the bumpstops, which is really shity ride quality by the way.
My question is: is there anyway to keep the car that low and not have the shocks riding on the bumpstops? How do all those ricers do it with slammed cars? Maybe they dont care and all have this problem?? If I cant fix this soon, Ill just raise it up an inch.
Thanks in advance for any comments, and no flames.
Old Oct 4, 2002 | 04:54 PM
bullz's Avatar
Default Re: Slammed (ridge racer 2)
raise it up an inch
Old Oct 4, 2002 | 05:30 PM
95SiGuy's Avatar
Default Re: Slammed (Muckman)
Did you reuse the stock bumpstops? If so did you cut them in half? Most aftermarket springs/shocks say to in the instructions, if you didn't that'd give you some extra suspension travel.
The 'ricers' that slam their cars that far just put up with a crappy ride. You're better off raising it back up an inch or so.
Old Oct 4, 2002 | 06:14 PM
Muckman's Avatar
Moderator in Chief
Default Re: Slammed (95SiGuy)
Yeah bumpstops are cut in half.
I guess Ill raise it up an inch
Wheel gap is so fugly
Thanks for the feedback
Old Oct 4, 2002 | 07:14 PM
976's Avatar
976
New User
Slammed is rice? Hmmmm. Race sus. and adjustable struts are not rice.
Cut springs are rice.
You need an alignment, your tires are not totally flat leaving you with loss of performance. Your camber, and toe might need to be upgraded, unless you raise an inch or so, then just an alignment.
Balence and rotate of course. You're losing performance...
Also, what buschings are you using, if you take a fast corner your tires might bend, you might consider polyutherothane. Engery Suspension has a good name.
Old Oct 4, 2002 | 07:15 PM
Sonic's Avatar
Your other option is to have Koni shorten the body of the shocks for more travel, but that's not cheap, where raising it an inch is free.
Old Oct 4, 2002 | 08:06 PM
carl_aka_carlos's Avatar
Default Re: Slammed (Sonic)
you can get higher rate springs, you can raise the car up an inch, or you can have your koni's shortened for like $100bux each, roughly.....i'd just raise the car that one inch
Bruce Banner
Jul 30, 2007 10:22 AM
mikeunreal
Suspension & Brakes
Nov 1, 2005 04:30 AM
90hbvtec
Suspension & Brakes
Jun 26, 2005 09:06 AM
hybrid901
Honda S2000
Jul 10, 2004 02:24 AM
cbrf-3
Feb 9, 2004 10:05 AM
