JDM F22B Dohc non vtec timing belt
Old Sep 13, 2011 | 09:59 AM
redprelude93's Avatar
Default JDM F22B Dohc non vtec timing belt
i have a F22B Dohc non vtec, my timing belt snapped, do i have to get the head machined? or can i just put a new timing, how can i tell if my valves are ruined with out pulling off the head? WHAT DO I DO!!
Old Sep 13, 2011 | 12:35 PM
q16racer's Avatar
Default Re: JDM F22B Dohc non vtec timing belt
Compression and leakdown test will tell all
Old Sep 14, 2011 | 08:11 PM
horsepowerless's Avatar
Not sure if this helps, as i have the single cam F22A1, but about 40,000 miles ago my crank pulley fell off (a month after i bought my car). anyway the local mechanic just bolted it back on and its been running fine ever since. (it did run for a minute like this before i figured out what the F*** happened and turned it off too.)
Old Sep 15, 2011 | 06:04 PM
rebuild_it's Avatar
your gonna want to run a compression test to make sure your valves arnt bad
i just did this rebuild on my DOHC f22b so if u need any part numbers or anything let me know
here is a site that helped me http://www.tegger.com/hondafaq/f22b/index.html
Old Jun 13, 2022 | 06:42 PM
Backroadsracing's Avatar
yo I'm doing the timing belt on my f22 dohc and I can not find where to buy the right belt to save my life
ekdriver707
Dec 4, 2013 05:01 AM
GsrTurboCRX88
21
Dec 31, 2006 11:57 AM
carr
Nov 22, 2006 07:41 AM
jccigt
May 12, 2006 08:59 AM
Inaniac
10
Jun 15, 2001 03:40 PM
