Blew my timing belt last night.........
Old 06-15-2001, 05:34 AM
New User
Inaniac's Avatar
Default Blew my timing belt last night.........
Am I screwed ? I once heard then when the timing belt snaps it sometimes causes the valves to bend on the vtec engines.....
Old 06-15-2001, 05:48 AM
DragII's Avatar
Default Re: Blew my timing belt last night......... (Inaniac)
honda engines are interference engines..there for when the belt snaps...9x out of 10 your valves will hit your pistons and bend....you need to do a compression test to find out how bad it is.
Old 06-15-2001, 05:57 AM
JimmieD's Avatar
Default Re: Blew my timing belt last night......... (DragIIcivic)
Mine broke last month and i had no problems....were you driving or idling? I was idling so i was lucky i guess.
Old 06-15-2001, 06:09 AM
New User
Inaniac's Avatar
Default Re: Blew my timing belt last night......... (lsinteg)
BLAST! I was drivin..... doin bout 45..... wasnt driving hard or nothin..... but :: guess im screwed.... how much is this going to run me ? anyone know ?
Old 06-15-2001, 06:14 AM
DragII's Avatar
need to find out if actually damaged anything first..at worst...you'll need to replace bent valves, possibly a piston...you could be up to 2g's at that point...but at best...it'll be nothing...and you'll get out for around 500 for a new timing belt and diagnostics.
Old 06-15-2001, 06:18 AM
New User
Inaniac's Avatar
ok well if it does end up running me into the 2g area.... should i fix or just go for the dohc....
Old 06-15-2001, 06:20 AM
DragII's Avatar
you could buy a new sohc for $600 or under used...
Old 06-15-2001, 07:35 AM
ATYPR's Avatar
Swap
Old 06-15-2001, 07:53 AM
New User
Kalokohan's Avatar
Default Re: Blew my timing belt last night......... (FUCATYPR)
If the estimate of replacement is in the three digit area, go ahead an swap it.
Old 06-15-2001, 10:39 AM
JimmieD's Avatar
Default Re: Blew my timing belt last night......... (Unleashed5GHBGS-R)
You are probaly going to spend about 500 +/- for replacing timingbelt, pulley belts adn new water pump. I would do that if you have no bent valves but you really cant tell unless you pull head or put belt on first!!! Did you try strarting it after it stalled???? b/c if you did they are bent! Do a swap you wont regret it at all. And everything you need is already there. You probaly have the easiest car to swap a dohc in.
Old 06-15-2001, 03:40 PM
New User
Inaniac's Avatar
no it wouldnt start afterwards..... and all my belts (cept the timing) are practically brand new .... they came with my pulleys... so i should just swap it eh ?
Gvis420
13
12-20-2009 12:24 PM
cleanazcoupe
03-16-2009 04:08 AM
lsvtec2000
01-01-2008 08:03 PM
Mr.Death
07-20-2006 11:08 AM
AK94GSR
05-10-2002 09:39 AM
Quick Reply: Blew my timing belt last night.........
