LSVTEC cams advice......
Goal, want 200+hp range
currently at 192hp 139lbs
my set-up
b16 head
ctr complete valvetrain , cams/dual valves springs/retainers
3 angle valve job
blox im
passwordjdm thermal im gasket
aem tru cam gear
310cc
walbro 255
password ***** intake
replica hytech header
aem fuel rail
stock ls block
ctr pistons
arp head bolts
oem headgasket
b16 tranny
2.5" colletor from hytech header down to 2.25" hks catback exhaust
My question is, is it worth upgrading to skunk2 pro stage 2 cams or something similair like blox, crower, toda, buddy club etc...compare to my ctr cams to push me extra 20+ hp?
my set-up
b16 head
3 angle valve job
blox im
aem tru cam gear
310cc
walbro 255
aem fuel rail
stock ls block
ctr pistons
arp head bolts
oem headgasket
b16 tranny
That compression ratio + large cams can equal some issues. I would personally stick to something a tad more mild and if you do decide to run Pro 2's you should clay the motor/ check clearances.
So you just wanna break the 200 whp mark?
I'd start with ditching the jdm whale dick ***** password intake and get a straight 3" cold air intake with a BPI velocity stack/filter.
You didnt mention if your tuned or not. That will get you over 200 whp by itself AND give you more power "under the curve" which is more important anyways...
Damn I read right over that....this motor has LOTS of potential tied up in someweat crappy parts. I too am cringing thinking about pro 2's with the CTR domes though....
OP was that dynod on a mustang, dynojet or dynapak?
I agree with ditching the whale *****, upgrading to a 3 inch exhaust if you don't mind some noise, and ditching the blox IM.
Hell the first 2 alone would probably get you to 200 on the same dyno you made 192 on.
Also I have a edelbrock 65mm tb, should i go bigger?
Skunk2 IM is fine and so is the 2.5" exhaust. For just 200whp, a 3" is beyond being necessary. And yes I have 2.5 and 3" on both my hondas. Ain't needed. But for god's sake that CTR/LS block/Pro2 cam combo is seriously asking for trouble. big trouble.
Trying to spend my cash wisely for atleast 20hp gain.
Funny thing is my tuner recommended me the skunk2 stage 2 if I wanted to make the 200hp range.
I'm going to call him tomorrow.
match it with my edelbrock 65mm tb, how much hp you think I will get out of this?
Thanks, and why is that?
ive seen 5 whp on the velocity stack intake alone...with that and a 2.5 or 2.75 inch exhaust you should see 200whp...but cams will defitnetly open that engine up...mikeyspec made 235+ with blox cs i think the jun3 replicas...and a similar setup..
velocity stack http://www.bpinitiatives.com/filterkits.php
2.5 exhaust kit (weld it up yourself)http://vrsexhaust.com/TUBING_KITS/HO.../honda_tk.html
I'd start with this...
You better clay your engine and know your PTV, PTH, and VTV clearances before going with bigger cams. I bet things are already pretty tight in there as it is.
3" CAI with velocity stack
2.5'' exhaust
Skunk2 Stage 2 Tuner Series Camshafts
Seems like the right combination to take you over 200 whp. This setup has been tried and tested many times.
2.5'' exhaust
It should have a part number mark on each cams to indicate skunk2 cams correct? The reason I ask is a local guy has one for sale for half the price.
Thanks
not to jack your thread but i've been wondering the same exact thing except i have a blue printed balanced block and crank,eagle h beam connecting rods and je pistons which i think is 10.2 to 1 cr.i've been wondering what head set up to go with before i put it together.
PtV = piston to valve
PtH = piston to head
VtV = valve to valve
as in contact. Gotta make sure you have enough clearance for each relationship that you don't get contact between the above pairs of components.
If you or your tuner is capable of using Crome, there's probably no need to change your EMS.
What brand like crower, blox close to s2 stage 2 tuner cams
i hear buddy club spec 4s, sk2 stg 2 , blox bs ,and endyn bumpstiks...are all base on jun3 which are some of the best cams ever made...but they all have their own tweaks that mak them a lil diff except for blox which are carbon copys of the sk2...
