non d16 on d15 block.. will it fit with other stuff?
Old Sep 12, 2011 | 05:49 PM
panchlow's Avatar
Default non d16 on d15 block.. will it fit with other stuff?
head***
as in the stock header manifold timing belt nd distributor?
would i hav to buy the d16 stuff?
my original engine is a d15b7 nd the head is off a 98 dx
Old Sep 12, 2011 | 08:13 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: non d16 on d15 block.. will it fit with other stuff?
Flange is the same flange pattern for the intake manifold and exhaust manifold regardless of head from 88-00 SOHC D-series so you're good to go in that respect. The distributor has the same flange pattern as well for 88-00 SOHC D-series with the EXCEPTION of the 92-95 SOHC VTEC and VTEC-E heads, they have their own unique flange pattern but since you're using a 98 DX head you are good to go for the distributor. In regards to the timing belt I'm not exactly sure which belt you'd use, you may have to search around for that one if no one chimes in with the answer.
hammergunner
Jun 18, 2009 11:39 AM
re5513
Apr 6, 2007 07:30 AM
doublejz
Sep 21, 2003 03:29 PM
rocket3004
May 1, 2003 11:44 AM
jdm92civic
Aug 5, 2002 11:45 PM
