Went over crack in pavement and car now pulls to the right
Old Sep 12, 2011 | 03:16 PM
fromthesun_93's Avatar
Default Went over crack in pavement and car now pulls to the right
I recently did the alignment on my car. A few days ago i was driving and i went over a small crack on the pavement and the car pulled to the right. For some reason i cant figure out whats making the car pull. Any suggestions?
Old Sep 12, 2011 | 03:17 PM
B18CivicEJ8's Avatar
Default Re: Suspension problem
What size rims and tires?
Old Sep 12, 2011 | 03:25 PM
BryanM.'s Avatar
Resident Gearhead
So you went over a crack and since then it pulls to the right? Kinda don't get
what you mean...
Did the car take an alignment or did the tech just get it as close as he could?
Did they give you a copy of the numbers?
Old Sep 12, 2011 | 04:47 PM
98civdx's Avatar
Master Detailer
^^ That, also, what is the condition of the tires?
Old Sep 12, 2011 | 06:19 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Went over crack in pavement and car now pulls to the right
Does crack mean pothole?
Old Sep 12, 2011 | 06:37 PM
98civdx's Avatar
Master Detailer
I was thinking the same.
We've got pot holes here that would tear the suspension right out from under the car.
Old Sep 12, 2011 | 07:35 PM
16 Inch rims all four tires. Front tires 205-40-16. Rear Tires 205-45-16
what you mean...
Ok. Before i did the alignment to the car, the car would literally pull to the right REALLY bad. i.e i would let go of the steering wheel and the car would pull hard to the right. I was always in a pulling battle with the steering wheel. Anyways, i took it to the shop and the guy said he did the best he could, which he did. Now i can let go of the steering wheel and it stays straight, but still pulls slightly to the right but not as much. Now whenever im driving and there's 'cracks' on the pavement the car still tends to pull to the left or right. Now when i mean 'cracks', i mean like repairs to the pavement and even changing lanes on the highway. As for numbers, i really dont know. All he gave me was a receipt with items that i need to replace. (tires) I can check it for numbers..
From lack of alignment, the front tires are in need of R+R.
No, more like repairs to pavement etc.
Old Sep 12, 2011 | 07:43 PM
Linked's Avatar
like a big step in the pavement from when roads are repaired?
inspect your rims for any bent areas
jack the front up and check the tie rods and any bent control arms
before you get an alignment, you need to replace tires if its down to the belt because broken belt or badly worn tires will produce a pull even with an alignment
98civdx's Avatar
Master Detailer
If it's pulling left and right, you may just be in a groove.
Old Sep 12, 2011 | 07:58 PM
If the surface is not smooth, the car will pull. Also, When i drive the car the steering wheel feels really wobbly, espcially at high velocity. My rims are fine. I'm assuming that when i took it to get aligned the guy should have told me that i have something else wrong with suspension right? But then again it wont hurt to check it out.
What?
Old Sep 12, 2011 | 08:28 PM
98civdx's Avatar
Master Detailer
Folowing the grooves in the road. It's not uncomon. My car doens't it all the time.
It can give the feeling that the car is pulling.
So you didn't get a printout from the alignment shop?
Old Sep 12, 2011 | 08:37 PM
I've driven other cars on the same surface and the outcome is normal. Yet on my Del sol it pulls like outta control.
The guy gave me a receipt, thats about it. I can check if it has any info etc.
Old Sep 12, 2011 | 08:38 PM
98civdx's Avatar
Master Detailer
Do that.
How are the bushings,ball joints, tie rods?
Old Sep 12, 2011 | 08:56 PM
I have never seen such a random *** post on my thread. Suspension folks! not profanity!
Anyways. most of bushings and ball joints are kinda worn out.
meangreenEG
Oct 6, 2009 07:45 PM
mike001
May 3, 2007 11:55 AM
civic91
May 23, 2005 01:20 PM
jdmkevin
Aug 23, 2004 05:15 AM
