Many CEL codes and fuse 15 keeps blowing/Suggestions for 98 civic hatch cx
4 codes and they are as follows
P1298 Electric Load Detector (ELD) Circuit High Voltage
P0135 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater Circuit Malfunction
P0141 Secondary Heated Oxygen Sensor (Secondary HO2S) (Sensor 2) Heater Circuit Malfunction
Now when I checked the codes today I also had a P0500 Vehicle Speed Sensor (VSS) Circuit Malfunction, but after I reset the codes all of them have come back immediately except the VSS code.
What should I look at? Is this an O2 issue? Im not sure where to start since there are so many codes. This happened out of no where last week. Car seems to perform the same but all the dash lights, headlights etc. blink. Not blink as if on and off but more like bright dim bright dim and it eventually stops. Any suggestions would be appreciated.
Devious951
10
Aug 29, 2009 10:22 AM
