Reverse Viberation
Old Sep 12, 2011 | 08:32 AM
1992honda's Avatar
Icon2 Reverse Viberation
More Problems!
When I put my 92 Accord in reverse It viberates like crazy. When its In any forward gear its smooth and tight. ATF is full..
Thanks for any help
Old Sep 12, 2011 | 08:37 AM
redbull-1's Avatar
Default Re: Reverse Viberation
Check the motor mounts.
Old Sep 12, 2011 | 08:52 AM
1992honda's Avatar
Thanks
Whats the best way to check them they look ok. And when I torque the engine there is no banging.
Old Sep 12, 2011 | 09:05 AM
redbull-1's Avatar
Have someone start the car and shift the car into reverse while you look at the motor mount areas. You may hear a clunk, look for movement like the engine block moving away at the rubber mount, at the moment the car is shifted into reverse. Since you stated there was vibration, you should see the engine block also vibrating when shifted to reverse.
Old Sep 17, 2011 | 10:09 PM
Bad_dude's Avatar
Check your front torque mount. Mine shakes in reverse and I am going to change it out next week. Might want to put some mount inserts to stiffen them up.
afnan
Sep 12, 2013 01:04 AM
vortexx
11
Dec 20, 2006 11:29 AM
mingbling96
Mar 12, 2005 01:12 PM
mattcalica
Jan 19, 2005 04:43 AM
Rocks
11
Jul 23, 2004 11:19 AM
