Open Ended Lug Nuts / Extended studs?
Old Oct 4, 2002 | 09:16 AM
AllMotorITR's Avatar
New User
Default Open Ended Lug Nuts / Extended studs?
I used to have some Kyokugen lug nuts and they worked great, but they got to be a pain in the *** after a while.. Who else makes open ended lug nuts of good quality? Also who makes extended studs?
Old Oct 4, 2002 | 09:25 AM
RTW DC2R's Avatar
Default Re: Open Ended Lug Nuts / Extended studs? (AllMotorITR)
is there a reason to have opened ended as opposed to the regular closed lugs?
Old Oct 4, 2002 | 09:28 AM
Austin's Avatar
Default Re: Open Ended Lug Nuts / Extended studs? (RTW DC2)
No reason unless you're using a spacer and would like the additional amount of threads on the nut...which he is not using.
Austin
Old Oct 4, 2002 | 09:55 AM
JeffS's Avatar
I'm happy with the Skunk2. They're going to run you about $100 a set though.
Old Oct 4, 2002 | 10:46 AM
PM-Performance's Avatar
Default Re: Open Ended Lug Nuts / Extended studs? (JeffS)
skunk 2's are nice .
Old Oct 4, 2002 | 10:52 AM
sgT's Avatar
sgT
Default Re: Open Ended Lug Nuts / Extended studs? (itr206)
I highly recommend AGAINST skunk2 wheelstuds and lugnuts.
10 of the 20 on my car either siezed, galled, stripped or snapped.
Some within the first month.
I recommend ARP studs.
Gong Show's Avatar
Jeff Sloan uses ARP extended studs. Alot of people complained about the skunk2 studs. I'll see if I have the topic saved.
Here you go, this link should work.
http://www.hybridautomotive.com/tech/arp_studs/
Old Oct 4, 2002 | 11:08 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default Re: Open Ended Lug Nuts / Extended studs? (sgT)
Damn Steve, why didn't you tell me earlier.
Mine snapped on me within 2 days.
Old Oct 4, 2002 | 11:15 AM
comptechgsr's Avatar
Default Re: Open Ended Lug Nuts / Extended studs? (Wai)
i'm anti skunk2 also...
on this one
Old Oct 4, 2002 | 11:26 AM
BERT-O's Avatar
Steve,
Really, what about their cams?
do they snapped as well?
whats your opnion?
thank you.
Old Oct 4, 2002 | 11:44 AM
Willard's Avatar
https://honda-tech.com/zerothread?id=288525
order a box of the "Extended Conical Seat Bulge Nuts ( Open End )" and use the stock studs.
There was mention (somewhere) of a CL-S/TL-S application (a little bit longer Honda stud) that could be used in a Intrgra hub...
Old Oct 4, 2002 | 12:32 PM
infinkc's Avatar
Default Re: Open Ended Lug Nuts / Extended studs? (Willard)
you can just use oem honda lug nuts, work fine for me with my extended studs. From a 94 accord ex they are openended, just use a deep socket
Old Oct 4, 2002 | 12:34 PM
eviltwin's Avatar
i was told in order to change the weel studs you would need to replace the wheel bearings. could this be true?
Old Oct 4, 2002 | 12:40 PM
Wai's Avatar
Wai
Default Re: Open Ended Lug Nuts / Extended studs? (eviltwin)
Depends on how long the studs are. The ones I have (I *think* they're from Spoon) are 10mm longer and removing the hub was not necessary for installation. Just find a right angle and slide it in.
Old Oct 4, 2002 | 12:47 PM
Gong Show's Avatar
hahaha, figures
Old Oct 4, 2002 | 01:21 PM
Wai's Avatar
Wai
Default Re: Open Ended Lug Nuts / Extended studs? (9Grandr)
We were talking about skunk2 extended wheel studs, not the lug nuts. I don't think skunk2 makes any lug nuts?
Old Oct 4, 2002 | 01:25 PM
Mario's Avatar
They do, the quality is up to par with their studs too
Old Oct 4, 2002 | 01:28 PM
n1ek's Avatar
Default Re: Open Ended Lug Nuts / Extended studs? (Mario)
right off the comptech website:
Made from 190,000 psi heat treated,
8740 chromoly steel. 12mm x 1.5 thread
Sized to fit Honda/Acura hubs without
modification. Sold in sets of 4.
Old Oct 4, 2002 | 01:55 PM
AllMotorMadness's Avatar
Skunk2 Racing Lugnuts
Old Oct 4, 2002 | 02:07 PM
Gong Show's Avatar
Yeah WAI, Skunk2 does make dud nuts... Im two short now, the threads on them are stripped now... And they cost like 80 bucks... They are super light, but super cheap... And they also get scratched up easy(not that it matters to me). But for that price, these lug nuts should be top notch...
First skunk2 product that I have dissapproved.
Old Oct 4, 2002 | 02:08 PM
skunked's Avatar
Default Re: Open Ended Lug Nuts / Extended studs? (AllMotorMaddness)
ARP Studs & Skunk2 Lug nuts. You won't have any problems with this setup.
Old Oct 4, 2002 | 02:11 PM
Gong Show's Avatar
Default Re: Open Ended Lug Nuts / Extended studs? (skunked)
102 bucks for a set of Lug Nuts, how long have you used the Buddy Club lugs??? I also use my skunk2's on the street, are you running your Buddy Club lugs on street and track?
TIA
Old Oct 6, 2002 | 02:50 AM
fressshhh's Avatar
what about these?
http://www.inlinefour.com/axulraclugnu.html
Old Oct 6, 2002 | 05:22 AM
Warren's Avatar
Wrong-Way Wang
Default Re: Open Ended Lug Nuts / Extended studs? (dyverge1)
The Axas lugnuts from Inline are really good. I've had them for a few months now on my racecar, and they hold up to abuse well. I zip them on and off pretty often, and the anondizing is still there.
Warren
Old Oct 6, 2002 | 05:26 AM
rolow's Avatar
Default Re: Open Ended Lug Nuts / Extended studs? (GONG SHOW)
TIA
The Buddy Club and the Axas are the same
I run the Axas on the street with skunk2 studs which suck I got five sets before I found 16 I could use
