ITR valves in B16A!
Old Oct 4, 2002 | 08:48 AM
evo's Avatar
evo
New User
Default ITR valves in B16A!
Going to fit ITR valves on Intake side only, apart from 3 angles valve job, what else do I need to fit in B16? Are they same length as B16A do I need ITR valve guides??
Thanks in advance.
Old Oct 4, 2002 | 08:54 AM
spettinger's Avatar
Default Re: ITR valves in B16A! (evo)
might as well do new valve guides. i would definitely do ALL the valves because i think you want equally flowing valves for both the intake and exhaust side or you might end up with a funny flowing motor. do new valve guides as well.
Old Oct 4, 2002 | 08:58 AM
SuperCivic's Avatar
Default Re: ITR valves in B16A! (wreckedhatch)
and while you've got it apart, you should do springs and retainers!
Old Oct 4, 2002 | 09:37 AM
evo's Avatar
evo
New User
Default Re: ITR valves in B16A! (SuperCivic)
Aren't all B-series has same diam. Exhausts valve?? Would ITR valve guides fit B16A?
Old Oct 4, 2002 | 09:53 AM
dohcsideSi's Avatar
why???????? your going all motor right?????
Old Oct 4, 2002 | 11:08 AM
rice_classic's Avatar
Default Re: ITR valves in B16A! (dohcsideSi)
you might as well replace the valve guides as well... but be careful, you need a special tool.
I'd just use "NEW" b16 valves... I don't see a wonderful benefit from ITR vavles.. only from an ITR valvetrain.
Old Oct 4, 2002 | 12:09 PM
evo's Avatar
evo
New User
Default Re: ITR valves in B16A! (rice_classic)
Yes I'm going all motor, The CTR piston, JUN'3, valve spring and ti-retainers will fit at same time, the ITR intake valves would be a bonus if add in the same time.
[Modified by evo, 9:10 PM 10/4/2002]
redlineintegra
Sep 20, 2005 10:43 PM
hifi_civic
Aug 9, 2005 04:13 AM
Ovl55rag
Nov 19, 2002 09:43 AM
evo
Oct 5, 2002 01:35 AM
JeffNA
May 24, 2002 11:01 PM
