Test Pipe and the stock cat...... differences
I just put on a test pipe (with the help of Steve).
testpipe
testpipe.com
they send me the test pipe, but it has two O2 holes.
they should send me a plug for the O2 hole. as it stood I couldn't find anything to fit the stupid hole. The threading was all jacked up, so I had to basically force the end of a spark plug in there to fit and plug the hole.
the O2 sensor doesn't like the air in there so it's setting off my check engine light
If I'm running a company I'm going to include a plug for the second O2 and maybe both or also put some sort of cap in there for the O2 sensor so it doesn't freak out.
oh well
as far as the sound goes it isn't very loud just at idle or just cruising. it does get a bit louder than normal when you semi hit the accelerator.
if you punch it you can tell a difference, but it isn't bad.
the smell isn't great, but it isn't that bed either.
when the VTEC kicks in you can hear the air shoot out of the exhaust a little harder (almost like a really hard silent fart)
at about 60+ mph it makes the car vibrate a bit more (feels good on the nut sack).
the biggest difference between cat and test pipe is when I let off of the gas.
it is really throaty and deep?
butt dyno-seemed to get up to 100mph pretty darn fast getting on the freeway.
for $40 dollars? why not
get a high flow cat also
test both and see which works best then sell the other one.
oh yeah.... don't bother emailing testpipe.com because they don't respond or at least have yet to respond (2 weeks).
testpipe
testpipe.com
oh well
they are a nice diff. the cel is inevitable unless they did something to stuff the bung with cat amterial , but its normal and those plugs are only a few buck at any ehxaust shop, now you got an extra bung for a wideband when tuning .
[quote[at about 60+ mph it makes the car vibrate a bit more (feels good on the nut sack). [/quote]
Test pipe is too big, or your O2 sensor is angled and resting on the shift linkage.
I've got a Gutted Stock cat..... Works pretty good..... DON'T waste your money on a Comptech POS high flow cat..... Mine lasted about 12000 miles, the screens fused together and restricted air flow.....
However, I still have this Gutted Comptech cat, if anyone wants it, let me know....
gulftiresinc
Sep 18, 2004 09:55 AM
