Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2003 Honda Civic EX P0300, P0302, P0301, P0303
Old Sep 10, 2011 | 04:57 PM
qinfujun's Avatar
Default 2003 Honda Civic EX P0300, P0302, P0301, P0303
Any help would be greatly appreciated!
Year: 2003
Make: Honda
Model: Civic EX, manual transmission
Engine: 1.7L sedan 4 Cyl ,
Mileage: 58,000
Stored:
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0300 Random Misfire Detected
Old Sep 12, 2011 | 12:55 PM
upcomintuner's Avatar
Default Re: 2003 Honda Civic EX P0300, P0302, P0301, P0303
Is it overheating any? And you could check your spark plugs for cylinders 1-3 or try switching one of those 3 coils to cylinder 4 to check the coils.
Old Sep 12, 2011 | 08:22 PM
It Wasn't Me's Avatar
Have you done or had any work done to it lately?
Old Sep 13, 2011 | 09:44 AM
fsanchezsmith's Avatar
i had a similar issue and fixed it with some cleaner called seafoam. u can buy this at a local aoutosupply store. suck up the liquid through the pcv. i havnt experinced any problems since.
Old Sep 13, 2011 | 10:41 AM
justinsbg's Avatar
Usually when the PCM stores a "random misfire" code along with cylinder specific codes it's ignition related. Have you replaced your spark plugs? They're due for changing on that model at 110k. If you have more than that on it I would change them. I would only use the NGK factory plugs. They're expensive but it's worth it in the long run. You also may have a failed ignition coil, especially if the spark plugs have significant mileage on them. If it's consistently misfiring under all running condtions, try unplugging each coil pack individually. You're wanting to see if when you unplug a coil pack if the engine runs any rougher or doesn't change at all. If the engine doesn't run any worse with a coil pack unplugged then that is the problem coil pack.
Old Sep 13, 2011 | 08:20 PM
hondarsr's Avatar
Hey bro I had the exact same problem w my 02 ep3 , I even got the same codes u have exact the problem is the camshaft it self I can bet 100 bucks the lobes are worn and grinded down and im sure tje rockers are no good as well.... Check the cam shaft this was a big problem in 02-03 civics especially si model.honda fixed the poor designed camshaft problem in late 03....hope this helps buddy
Old Sep 18, 2011 | 06:23 PM
atkach's Avatar
do you have any aftermarket parts?
Old Sep 22, 2011 | 11:40 AM
dealer_tech's Avatar
Does your gas gauge seem to move around alot, like taking turns and hitting bumps? I just thinking this may be fuel pump related, the plastic shell that houses the pump tends to come apart. Thus the pump kinda just flops around and could starve the engine of fuel. Just a thought.
Old Sep 23, 2011 | 03:10 PM
subworm07's Avatar
I just had the exact same problem and like hondarsr I fixed that and the coilpacks and no more problem. oh and I got a 02 civic ex
Yuen001
36
Jul 21, 2024 08:18 AM
Pudnite
Feb 11, 2018 04:46 PM
Jvega1691
Mar 25, 2017 10:24 AM
beachlizzy
Apr 9, 2014 10:48 AM
accord boy
Jan 30, 2008 04:37 PM
