Is this accord wagon worth buying??? help please
Old Sep 10, 2011 | 10:25 AM
xsole's Avatar
Default Is this accord wagon worth buying??? help please
http://philadelphia.craigslist.org/cto/2590397832.html
LX, 147k miles, the body looks pretty clean from the pictures. there is just a small dent on the hood and it doesnt close fully. the wholesale guy said the only main issue is that the car overheats after about 15 mins of driving. hes firm on 1300, so is this a steal?
Old Sep 10, 2011 | 11:39 AM
Lost Again's Avatar
Default Re: Is this accord wagon worth buying??? help please
If you can confirm it is not the HG causing the overheating before buying it....Inspect that "dent", looks like the car hit something, the bow in the hood??? Then if the owner can confirm TB replacement, I'd want paperwork....I'd go for it.
Old Sep 10, 2011 | 07:10 PM
xsole's Avatar
What is a way I can find out if it is overheating from the HG?
Old Sep 10, 2011 | 09:47 PM
75aces's Avatar
Not sure, but I think you can tell by the smoke from the exhaust. Could be blue smoke? See if you can grab the vin and verify thru carfax. It is a steal, but if there is a hg problem, lower price less than $1k. Good luck.
Old Sep 11, 2011 | 05:48 AM
Lost Again's Avatar
Leak down check is usually the best way....IMO-EDIT-look at AZ for a "Block Tester", fluid is $8, kit is $25. If the owner is up front, they should alow you do do this before buying the car. I've seen the kits for $25~$30 at stores.
Soc@lep3
Jul 30, 2006 01:55 PM
eboniwoman
14
May 14, 2005 03:12 PM
96AccordEX
Sep 18, 2004 12:13 PM
00WhiteEKy
Mar 26, 2003 07:35 PM
