Clutch Fluid Leaking By Clutch Pedal In Car
Old Sep 9, 2011 | 03:53 PM
curtie94's Avatar
Default Clutch Fluid Leaking By Clutch Pedal In Car
So I have been having problems with my clutch lately. When I take off the car car judders. Once the car is warmed up it is less prominent but still there. Could this be because I got air in the line or something. I looked at the clutch master cylinder and it was real low I couldn't see any fluid, filled it back up and same thing. What could it be.
Like I said it is leaking in the car where the clutch pedal pushes that plunger like thing.
Car is 1991 Honda Accord LX Coupe 5-Speed Manual
Old Sep 9, 2011 | 04:44 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Clutch Fluid Leaking By Clutch Pedal In Car
Leaking seal on the Clutch Master, repair or replace it.
Old Sep 9, 2011 | 04:47 PM
curtie94's Avatar
Is that why the car judders like that too.
Old Sep 9, 2011 | 04:54 PM
MAD_MIKE's Avatar
MM Gruppe B
Possibly not fully disengaging the clutch if its leaking/not holding pressure.
Old Sep 9, 2011 | 05:04 PM
curtie94's Avatar
Just a little more info, the slave cylinder has a squeak can that cause the car to hop like it does? Thanks for the quick replys.
Old Sep 9, 2011 | 05:30 PM
exb18c1's Avatar
There could be other reasons for that but start with obvious things that are need to be replaced first.
tercelrcr
Feb 2, 2013 06:25 AM
AllMotorRP
Honda S2000
Mar 23, 2009 07:41 PM
david236kEG
23
Jan 28, 2009 03:34 PM
Lb1atx
Sep 7, 2007 05:16 AM
Greenery18
Jul 8, 2005 04:22 PM
