axle problems.
Old Sep 9, 2011 | 12:53 PM
panda teggy's Avatar
Default axle problems.
im putting a d15b7 in my 4 dr but im having an issue with something as llittle as the axle. once i put the axle in and put the ball joint back on and everything the wheel hub spins just fine. but as soon as i tightne the axle bolt, think is solid as a rocl, wont spin no matter what i do. i thought it was the bolt so i got a new one and the same thing. im not sure whats going on. any ideas? thanks
Old Sep 9, 2011 | 01:00 PM
BiG ChOr!Zo's Avatar
Default Re: axle problems.
did you strip the threads on the axle...!!!
Old Sep 9, 2011 | 01:04 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
What "bolt" are you even talking about, or do you mean nut?
Old Sep 9, 2011 | 01:05 PM
No ive tried 3 different axles I have layin around.
Old Sep 9, 2011 | 01:06 PM
Yes nut my bad
Old Sep 9, 2011 | 01:09 PM
DO IT ON ALL FOURS
Do all of your axles have the ABS ring on them? Try removing the dust cover to see if you can spin it. If it does spin you know where you are binding at.
ralphieg
Oct 2, 2012 06:36 PM
flaxx0r
28
Dec 29, 2008 07:15 AM
nicko360
Sep 16, 2007 05:39 PM
david90
Mar 31, 2004 11:41 PM
philipkrotch
Jan 22, 2003 10:46 AM
