92 Accord No Heat
Besides a bad heater core, there could be a multitude of reasons as to why your heater doesn't work.
Your heater core could simply be plugged. Gain access to your heater core by removing the dashboard, removing the dashboard support pipe,
removing the 4 mounting bolts, and then removing the heater assembly. (pictured in this '92 Accord heater diagram)
After that, remove the heater core cover and put your hand on the fins of the core. If only some are lukewarm than the core is clogged.
Another possible cause for the lack of heat could be a bad thermostat, bad heater switch or even a low coolant level. Check your coolant level to ensure that you are within the specified acceptable range.
Good luck man!
Good luck man!
+2 that's the first things I'd check too. Those control wires on the rotating heat control **** are constantly getting tight and needing lube. While I was changing out the radio/cassette deck in mine for a new CD/HD radio deck I got in there and lubed the control wire and the switch box for the different heater/air vents. You can tell when it gets sticky. The buttons take a few pressings back and forth before the vents compy and light comes on.
Good luck man!
Good luck man!
