B18b1 tranny oil refill spot ??
There's a sensor( I think it's a sensor idk what it's called) but it's held by 1 10mm bolt and has a plug on it , unscrew the 10mm bolt take off the little sensor thing , get a funnel and make sure you know how much oil you need or have to put it in if it already has some
There is a 17mm fill plug in the side of the transmission above the drain plug. fill the transmission until the MTF runs out of the hole. You can either pump it in the fill hole or use a funnel and fill it through the speedometer gear hole.
You can fill from above with the speed sensor out, but proper level of fill is at the "oil in" plug with the car level. If "oil in" plug is out then you can not overfill. If you fill from above then you are filling a given volume which should be the correct amount with complete drainage prior.
Peter_404_21
Dec 30, 2008 08:54 PM
