Suspension & Brakes Theory, alignment, spring rates....
Eibach Suspension
Old Sep 8, 2011 | 07:22 PM
JR_Integra's Avatar
Default Eibach Suspension
Does anybody have any experience with the Eibach suspension system for the DC2 Integra??? I'm not talking lowering springs, I want to know about their coil over set-ups and sway bars... Also, what is the big difference between mono-tube and conventional set-ups??? What is better for the street??? I know mono-tubes are better for performance set-ups, but are they better on the street as well???
Old Sep 8, 2011 | 07:55 PM
PreyStayShun's Avatar
Default Re: Eibach Suspension
Their sway bars would be a big expensive mistake... 26mm in the front as opposed to your current 24mm bar...and 17mm in the back? No one loves Eibach like I do, but I'd never buy their sway bars. I'm currently running a 98 spec ITR bar in the front (25mm) and USDM ITR rear bar (22mm) Fantastic setup, neutral and responsive.
I've never driven either their coil over setups, but I'd be worried to buy them. Is this DC2 strictly track driven or something???
https://honda-tech.com/forums/suspension-brakes-54/eibach-pro-street-s-coilover-review-2839993/ <- Review
Too many other proven options in that price range and even lower man. AMR FTW if your going to spend 1100+
Just my $.02
Old Sep 12, 2011 | 07:28 PM
JR_Integra's Avatar
Alright, thanks a lot man. I was just wondering because I work at a shop that is a supplier of Eibach and I could get a nice price on their components. But if they aren't worth the money, I'll stay away from them. The DC2 is mostly street driven.
Old Sep 13, 2011 | 12:16 AM
MindBomber's Avatar
+1 Eibach makes fantastic springs, they're a big part of what make GC sleeves great, but the sizing of their sway bars makes very little sense regardless of the generation. It's as if they think we're driving rwd cars. Steer clear of them and go with oem, when your prepared to step up from oem there's lots of other great aftermarket options like asr and progress.
Old Sep 13, 2011 | 07:44 AM
Jackson's Avatar
The off-the-shelf sway bars from Eibach were designed well before the Integra Type R was even sold and the bar sizes were relatively conservative for street use. The 17mm rear bar is a great upgrade if you do not want to get a subframe brace. I used this on my eg before it became a dedicated track car.
Eibach has started to make more track oriented parts including a 25mm adjustable rear sway bar as well as mono-tube 2 way coilovers built in house. I'm using both on my car now and they're amazing!
http://www.jhpusa.com/store/pc/viewP...idcategory=169
http://performance-suspension.eibach...ivic__del_sol_
To the OP, mono-tube coilovers are better for all around performance and longevity due to being able to use a larger piston diameter.
Old Sep 13, 2011 | 09:17 AM
vtecvoodoo's Avatar
Future Texas Boy
The Integra bars were actually R&D'd using my GSR, which was in 1996. They were/are very conservative. Not too many people were running a big rear bar back then. Bar production was moved from Germany to our Corona office a couple years ago. Now our employees, who are enthusiasts, are more involved in what is being manufactured in regard to heights, sizing, etc. It's an exciting time at Eibach.
Like Tony mentioned, we have some new stuff that is amazing. Im running our R2 coilovers on my ITR and love them.
Old Sep 13, 2011 | 07:03 PM
builthatch's Avatar
MiG-21 superfan
if you need suspension info look no further than these two, imo.
Old Oct 28, 2011 | 02:06 PM
variable's Avatar
So I ordered the 25mm rear sway bar kit from JHPUSA. It showed up the other day, real nice. Came with the bar, ES bushings, brackets, bolts/washer, and adjustable endlinks. It also came with what appears to two fabricated mounting brackets. I am installing this bar in place of my USDM ITR rear bar, I already have a ASR subframe brace. The kit came with no instructions, but I went ahead and installed the bar. Everything seems fine. My question is was I supposed to use the two mounting plates supplies with the kit, or are those only for people who dont have the subframe brace installed? I went ahead and mounted the plates between the ASR brace and the bushing brackets.
Old Oct 31, 2011 | 07:07 AM
Jackson's Avatar
The plates are included to space the sway bar away from the ASR brace to allow clearance for the bushing stop rings. Without them the rings may come in contact with your brace. It sounds like you've installed it correctly.
Old Aug 21, 2015 | 02:41 PM
TegLS98's Avatar
eibach.com/america
I know this post is from a few years back, but are there updated options? Went to the JHPUSA URL and it is no longer in service.
Thanks.
Old Aug 27, 2015 | 08:26 AM
Reyes's Avatar
Here are good links.
25mm Bar
Eibach 25mm Anti-Roll Single Rear Swaybar Kit - 92-95 Civic / 94-01 Integra - JDM Honda Parts USA
Multi-Pro R2's
Eibach Multi-PRO-R2 Coilover Kit - Honda/Acura - JDM Honda Parts USA
I have been using both of these on my EG for a few years now and love them. I have used a handful of different setups on my car and prefer these. The 3-way adjustable bar is great because you can tune the bar to your needs.
The softest setting is a bump up from the JDM 23mm rear bar and the highest setting is close to the ASR 32mm bar. Most guys use the middle setting with good results.
There are quite a few track guys here in SoCal that are using this bar and the R2's.
Old Aug 27, 2015 | 02:01 PM
TegLS98's Avatar
25mm Bar
Multi-Pro R2's
Thanks Reyes, but way over my budget.
Superhatch
Dec 22, 2011 05:20 PM
4CDFED
Oct 4, 2006 04:16 PM
hbgsr504
Jul 28, 2005 11:32 PM
turbo se
Mar 31, 2003 07:46 PM
gsrpilot8000
Aug 11, 2002 07:07 PM
