got a quick ecu question bout m new k swap....
Old Sep 8, 2011 | 02:33 PM
delsizzle1's Avatar
Default got a quick ecu question bout m new k swap....
Well I just got a k motor and trans out of a n 03 ep3 and was wondering if I can use the Ecu out of an 05 type s....
The motor will be going into a del sol but I'm not to familiar with k swaps just yet....
Old Sep 8, 2011 | 05:43 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: got a quick ecu question bout m new k swap....
you can use the ecu from a type-S you will just need kpro.
then again I haven't really checked to see if they have base model calibrations...
Old Sep 8, 2011 | 06:21 PM
doood's Avatar
been there done that
Sorry spaz but 05-06 ecus can't be used for kpro. That's why us 05+ guys always gotta spend extra for the 02-04 ecus. And yes hondata does have base basemaps.
Old Sep 8, 2011 | 06:55 PM
delsizzle1's Avatar
so then pretty much im looking for a 02-04 ecu to run with my swap...
Old Sep 8, 2011 | 08:02 PM
doood's Avatar
Yes you can use either a pnd or prb
Old Sep 8, 2011 | 09:09 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
my fault I thought the 05 was already a kpro ecu from an 05. DOH
Old Sep 8, 2011 | 10:52 PM
delsizzle1's Avatar
PND or PRB?????
is that the ecu i should be looking for sorry new to the k's
Old Sep 9, 2011 | 02:14 AM
doood's Avatar
Yes pnd is out of a base prb is type s. Prb has reverse lock out sp if you ever want to ise a 6 speed tranny its the one to get but other than that once kpro'd it doesn't matter.
Old Sep 9, 2011 | 03:44 AM
turbohatchBnuts's Avatar
Check out hondata.com it tells you what ecus can be used and the features of Kpro.
Old Sep 9, 2011 | 07:00 AM
delsizzle1's Avatar
Alright koo guys thanks
Old Sep 13, 2011 | 11:26 PM
delsizzle1's Avatar
so this is the ecu i got was told it was off an 05 type s but is a\has
prb on it does that mean its compatible with my motor????
Old Sep 14, 2011 | 02:46 AM
The last letter numbers A13 =2005-2006. A13-A16= 2005-2006 ecu.
Old Sep 14, 2011 | 07:10 AM
delsizzle1's Avatar
so the number im looking for than is what like A12 and below?
Old Sep 14, 2011 | 08:20 AM
For 2002-2004 prb ecu look for A01-A12 & 305 . All this info is @ hondata website.
Old Sep 14, 2011 | 08:31 AM
delsizzle1's Avatar
Alright koo thanks man
ub3rn00ber
Jan 7, 2011 03:26 PM
91sidude
Jun 29, 2008 03:11 PM
ballinsk8er
Jun 7, 2006 02:15 AM
stemiched
24
May 26, 2006 05:39 PM
