FS: Tein SS coilvers, 96-00 Civic
I have a full set of Tein SS coilovers for 96-00 civic. These ride really well and have full height and dampening adjust-ability. None are blown, all in good shape. Never seen winter iirc (Previous owner installed them). About 25-30,000 miles on em
Only pic ATM. Will include oem top hats and height adjuster thingys
What you're getting (NOT MY PICTURE)
$630 shipped.
$630 shipped.
448#/224#
http://www.tein.com/tech_info/h98.html
Yes I have the spanner wrenches and I feel like these will get to stock height or close. Heres the drop that it had with about 2-3" left to go higher:
Yes
Shocks and springs are completely interchangeable between 92-00 Civics and 94-01 Integras; the only difference between Civic and Integra springs is the spring rates. Also, the lower control arm bushing that connects the LCA to the shock absorber on the 96-00 Civics is significantly thinner than the bushing found on the 92-95 Civics/94-01 Integras. In order to swap components between the two, the bushing will either need to be ground down or replaced (if using 96-00 shocks on 92-95 Civic/94-01 Integra LCAs) or you will need to use spacers (if using 92-95 Civic/94-01 Integra shocks on 96-00 Civic LCAs)
