Suspension & Brakes Theory, alignment, spring rates....
BLOX adjustable end links
Old Sep 6, 2011 | 10:14 PM
chiprez's Avatar
Default BLOX adjustable end links
Anybody use them?
What's a recommended lenth?
Just asking cause I did and Intergra sway bar instalation in my EG.
Old Sep 7, 2011 | 07:03 AM
98civdx's Avatar
Master Detailer
Default Re: BLOX adjustable end links
I do, they suck. Failed about a year later, now every bump I hit I hear rattling, knocking,pops. It sounds like something is loose in my car, when noithing is. I run them front+rear.
Take a look at OEM integra endlinks, OR, F7/ASR endlinks.
Old Sep 7, 2011 | 07:50 AM
Libertariat's Avatar
Ek Forever y0!
I think the function7 endlinks are ~$50, the ASR ~$70
Neither ware that much more expensive than the blox endlinks.
Old Sep 7, 2011 | 07:55 AM
PreyStayShun's Avatar
I used to rock the ASR's....squeeky lil things, probably pretty standard for adjustable end links if I had to guess. Damn near drove me crazy.
PS- In the future just give responses a lil time buddy, no need to re-post.
Old Sep 7, 2011 | 08:14 AM
chiprez's Avatar
Damn. Got those end links cause I was in a jam. I got them in the mail yesterday and didn't want them all to much anymore.
Old Sep 7, 2011 | 09:09 AM
Ek Forever y0!
Return them.
And white lithium grease does wonders for squeaky suspension components.
Old Sep 7, 2011 | 12:22 PM
chiprez's Avatar
For sure.
Thanks for the advice.
Old Sep 7, 2011 | 02:16 PM
Ek Forever y0!
By the way, Liquid Wrench brand has a spray white lithium grease that works very well. Good stuff, albeit a little expensive.
Old Sep 7, 2011 | 02:28 PM
98civdx's Avatar
Master Detailer
The reason why the endlinks are going to be a little noisy is the spherical bearing.
Give them a squirt of wd40 1-2 a month. And do NOT lube them.
if you can't return the endlinks, just run them. Try to keep them clean.
Something to remember, these endlinks will not last nearly as long as OEM. I wouldn't expect to get much more then a few years out of them. Even F7/ASR, it's just how they are, sphericals don't last.
Old Sep 7, 2011 | 06:54 PM
After buying my DB I purchased endlinks from rockauto since I was already in the process of redoing the whole suspension. It was a shot in the dark but they're working great thus far and the bushings seem to be holding up well. I've only got about 7-10k tops on them though.
BECK/ARNLEY Part # 1015155 (part number for GSR endlink) They were $11.46 each.
Nothing wrong w/anything mentioned above of course, this is just the route I chose to take.
Old Sep 8, 2011 | 12:39 AM
chiprez's Avatar
Damn. Completely forgot about Rock Auto. Have had good experiances with them in the past.Haven't had a chance to try and return my endlinks back to JHP USA yet but did post them up fpr sale locally.
Old Sep 8, 2011 | 07:13 AM
98civdx's Avatar
Master Detailer
Eh, good luck returning them. I have had bad expereicnes with JHP in the past.
Old Sep 8, 2011 | 10:20 AM
chiprez's Avatar
This is my fist time dealing with them. Ill see how it goes.
Old Sep 9, 2011 | 02:19 PM
chiprez's Avatar
Also. I can't seem to find a good "installed" pic of the endlinks. Mainly curious as to where the "spacers" go.
Old Sep 9, 2011 | 02:49 PM
98civdx's Avatar
Master Detailer
the angled part faces the spherical part.
Like this, >Endlink<
<- being the washer.
Old Sep 9, 2011 | 04:27 PM
chiprez's Avatar
Yea I imagined that's how it went but one pair of bolts came with a thicker washer on one end as opposed from the other washers.
I know my description very vague. Thanks.
Old Sep 9, 2011 | 10:14 PM
98civdx's Avatar
Master Detailer
Right, they do, as did mine.
Use the bigger washer to try to make the endlinks as straight as possible, sorry I should have remember that. lol
Old Sep 10, 2011 | 07:53 AM
chiprez's Avatar
Cool man. Thmbks for the advice and my noob status around here.
honda kartel 2
Mar 4, 2014 01:32 PM
Xathine
Suspension & Brakes
Sep 25, 2013 11:04 PM
amej8
Suspension & Brakes
May 19, 2009 03:42 AM
VTEC_PRODUCTION
Suspension & Brakes
Dec 29, 2008 08:42 AM
a1k0n
Feb 17, 2002 12:38 PM
