need help??? LEaking Gas
Old Sep 6, 2011 | 08:46 AM
SIKNASTREXO's Avatar
Default need help??? LEaking Gas
got crx b16
noticed a puddle of gas behind front driver side tire.
It seemd to b leaking near bottom of master power cyclinder..that the big black thing in front of Brake cyc...
No signs inside of leaking clean behind pedals, not smells inside
Any info please
Old Sep 6, 2011 | 09:37 AM
JDpower's Avatar
Default Re: need help??? LEaking Gas
Check your line from your fuel pressure regulator back to the firewall(holes/loose clamps) because thats the area that your describing.
Old Sep 6, 2011 | 09:42 AM
thanks ..will check that out...
Old Sep 6, 2011 | 09:53 AM
4drEF's Avatar
Keyboard Humorist
If the leak is still being a bit evasive, try wrapping the lines and connections with paper towel.
Then turn the ignition to 'on' so the line pressurize and then 'off'.
The paper towel will be wet where the leak is.
great tip..thanks
tolowhb
16
Jul 24, 2020 07:37 AM
SIKNASTREXO
Sep 6, 2011 01:38 PM
HamiltonRex
10
Feb 7, 2006 05:46 PM
BlazeTeck2000
Nov 22, 2005 04:12 PM
