86mm next build
Im not 100% positive on this but with the b20 blocks many shop wont resleeve it because of its design, it sinks or leaks after a while. Only shop ive seen the b20 get resleeving from is Golden Eagle. But like i said im not sure, you need to double check with the other companys.
btw, what is your engine specs going to be? why are you going such a big bore on these b-series? Personally i wouldn't waste a newly sleeved block by going straight to 86mm bore unless its a race only engine with a big stroke crank underneath it.
hoskos
Dec 12, 2005 08:08 PM
TypeR0149
Aug 22, 2001 12:32 AM
