b series shift linkage
Old Sep 5, 2011 | 10:57 PM
demonicivis1320's Avatar
Default b series shift linkage
Can some one post pics on where I got. TO cut to make my own linkage out of a integra linkage please and thanx
Old Sep 5, 2011 | 10:59 PM
.Manny.'s Avatar
Touching My Member
Default Re: b series shift linkage
Cut and re-weld 2-3/8" off both straight sections
Old Sep 5, 2011 | 11:03 PM
2x3/8 is all I got to cut in the straightest part of the linkage?
Old Sep 5, 2011 | 11:10 PM
MarkOlson's Avatar
OG Hot Rodder
2 and 3/8" is what we cut out of the straight section for my son's 88DX with a B18A/Y1 transmission and it worked fine.
Old Sep 5, 2011 | 11:12 PM
Ty for the quick replies
Old Sep 6, 2011 | 02:52 AM
Spug's Avatar
Make sure you mark it before you cut it so that it's not twisted improperly when you weld it back together.
Old Sep 6, 2011 | 03:59 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Since when? I have always used around 1-3/4" as a starting point and thought that was the accepted norm?... You can always position the shifter forward or backward by taking more or less out...
OP - it helps to search, I got on the Google and this was the first page that popped up...
http://www.performanceforum.com/wesv...r/shifter.html
Old Sep 6, 2011 | 08:38 AM
.Manny.'s Avatar
Touching My Member
Since about 06 when I did mine. I was taught to cut that much and it worked out perfectly for me. The shifter sits centered and I've never had an issue.
unabonger
14
Jul 1, 2020 03:34 AM
kp
Nov 30, 2011 06:37 AM
Fo-Do Fanatic
11
Feb 15, 2011 11:10 AM
SupraRXZ
Feb 9, 2006 04:35 PM
dose
Nov 11, 2003 01:51 PM
