Official static compression calculation???
Old Sep 5, 2011 | 09:04 AM
crazydominicanman's Avatar
Post Official static compression calculation???
Ok so after speaking with multiple tuners/builders I can't seem to come up with a fit answer here. I am in the process of building a high compression ls/vtec. According to a compression calculator I used recently I got a static compression ratio of 12.4:1, seems kind of high. Just want to clarify on exactly what compression I will be working with here. Maybe I am just comp calculator dumb
Rundown:
Gsr head base - Ported/polished/3 angle valve job/shaved 0.010"
Ferrea SS valves
Supertech valve springs/retainers
B18B1 base - Decked 0.010'' and bored to 81.5 mm
81.5 mm USDM ITR spec pistons w/ new rings
3 layer headgasket
Cc's of displacement - 1857
Old Sep 5, 2011 | 10:08 AM
C_Rock77's Avatar
Default Re: Official static compression calculation???
You really found it necessary to list all that $hit....really? You couldn't just list the pertinent details?
I hope to God your head wasn't shaved 0.1"...if it was, it's junk.
12.4:1 sounds right. IDK why you think it sounds high....
Calculators are just for an estimation. If you want an EXACT calculation, you're going to have to do some work....CC the combustion chambers and the pistons and do the math.
Old Sep 5, 2011 | 10:34 AM
Thanks for the input..
Old Sep 5, 2011 | 03:59 PM
Turbo vw's Avatar
why do you fill thats hi for the set up your using usdm p73 pistons witch have something like a 3.64 dome ls crank and rods 89mm stroke and your running a GSR head witch started with something like 41.60 CC volume and u milled it down .010 that should be right + the 81.5 bore bumps it up a tad bit
Old Sep 5, 2011 | 04:23 PM
pr0honda's Avatar
So, your head CC's are?, your gasket cc's are?, your cyl. +.- cc's are? Your cyl. displacement is? That is the only way to know. A NGK 06 VS an 10 spark plug changes your compression ratio, when you figure that out reply. Same as stock VS Ferrea valves or Supertec.
Old Sep 5, 2011 | 08:34 PM
I won't know the head cc's, or gasket cc's, or cylinder numbers for now since the motor is currently in the machine shop getting the bottom end balanced. The cylinder displacement is 1857
Old Sep 5, 2011 | 10:20 PM
C_Rock77's Avatar
Well then, take them the head and have them CC it and calc your final compression ratio.
Old Sep 6, 2011 | 06:42 AM
CHEETAH's Avatar
10 thou off a GSR head has to be cc'd...it starts off as 42.7cc and reduces from there but not lineraly because of the way the chamber is shaped...BTW the ITR/B16A does reduce linearly as an FYI.
12.4 doesnt sound too far off from milling off 20thous in total between the head and the block (including flat faced ferrea valves) and 0.5mm overbore.
Old Sep 6, 2011 | 08:31 AM
The first part of your 2 verses threw me off a bit? Call me a newb in the whole head discussion thing but I know the gsr head is square port as oppose to the circle port of the itr/b16 making it a bit more favorable for the all motor application that is why i sourced one, alot cheaper than itr.
Old Sep 6, 2011 | 10:47 AM
CHEETAH's Avatar
thats correct, so if you mill 10thous from the b16a/itr head you can simply use the volume formula for a cylinder to calculate the cc amount to deduct from the original 43.xx cc that the stock itr/b16a volume is...but because you have the squareport gsr head you cannot use that cylindrical formula to calc the cc to deduct from milling the gsr head by 10 thous...
Old Sep 7, 2011 | 09:07 AM
Ahhh now we see eye to eye lol..so how would one go about doing such with a gsr head? I am sorry for the newb questions, I want to learn correct, not hearsay.
Old Sep 7, 2011 | 09:39 AM
C_Rock77's Avatar
The best, most accurate way, as Cheetah told you, is to have the chambers CC'd with all the stuff in place that you're going to use (spark plugs, valves, etc).
Old Sep 7, 2011 | 10:08 AM
Ok. Thank you.
ticket_target
Nov 11, 2006 11:26 AM
tomlinson619
May 11, 2006 05:00 PM
zoom545
Nov 22, 2005 09:04 AM
PirateMcFred
Jun 17, 2004 09:23 PM
OneThirtyEight
Dec 1, 2001 10:19 PM
