evil codes #43 and #41
Old Sep 5, 2011 | 08:55 AM
hondatuned860's Avatar
Default evil codes #43 and #41
hey everyone ive got the evil code of 4-3 fuel system supply....i have recently changed the fuel filter, oxygen sensor has maybe 10,000 on it, fuel pressure regulator just changed last week and now i get these two codes. i was wondering if it could be the fuel pump because there are times when it totally cuts out while driving. i can be going along in third gear at about 3,000 rpms and it spits and sputters but then i mash the throttle and it clears right out. is there anyone who might know what is happening here? i was thinking maybe a bad ground, relay, or the pump itself.....PLEASE HELP!!!
sorry forgot to mention the 41 code....new OBX-r o2 sensor....im stumped.. i've searched this site and have tried to get answers on clubintegra.com to no resolve....the best answer i got is check the return line which i have done its not kinked nor is it plugged so anyone with some info for me would be much appreciated....
I also forgot to mention the sputtering has been happening for a while now...id say about 6 months but just got the check engine light about a week ago if that helps
Old Sep 7, 2011 | 09:32 AM
Default Re: evil codes #43 and #41
so i ordered a fuel pump and we'll see if thats the case if not ill keep everyone whos looked at this posted with anymore problems that might develop
Old Sep 18, 2011 | 04:36 AM
UPDATE: still having problems after fuel pump change, sea foam intake cleaning and sea foam injector fuel additive. i just dont have the slightest idea as what it could be. anyone that could give me a pointer or 2 it will be greatly appreciated.....
Old Sep 18, 2011 | 05:43 AM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
bottom of first post is 41 and 43 troubleshooting
Old Sep 18, 2011 | 04:59 PM
Originally Posted by HondaPartsHero
https://honda-tech.com/forums/showthread.php?t=1812135
THANKS!!!!! i bow to you...... i had no clue where ot even start anymore. so thanks alot for this ill check into it soon and keep you posted.
Old Dec 21, 2011 | 11:45 AM
fourthaxis's Avatar
Update? Did the sputtering problem go away once the car warmed up? The car would only cut out at low load, but fine at WOT?
91blackEF
Apr 5, 2021 03:23 PM
DEFIANCE
Aug 14, 2014 09:38 PM
91 luder
Aug 28, 2012 04:16 PM
Dubs13
Aug 27, 2009 07:22 PM
dis_epix3
Aug 31, 2006 03:52 PM
