second all motor build
Don't kno what to go with this time currently I have a built ls block and a built gsr head car makes just over 240hp..now I wanna do another build and iv got ideas just wantes to kno what else is a power house combo
wat is ur goal for the second motor?
hp wise?
wat is it gonna be use for?
ect ect....
if u still planning to stay b-series, 240hp is pretty good already, u can get maybe 20-30more hp only outta of these b-series if u using the 87-89 stroke, otherwise u need a bigger stroke to get more hp and tq.
hp wise?
ect ect....
for a 2L i will do
stock gsr/b16 head
refresh the valve job
stage2 cams
stiffer valve springs/stock retainers
itr/skunk2 or jg victor x manifold
65-68mm tb
440cc injectors
a decent header
b20 block
rs machine ITR spec 84-85mm pistons
stock rods
arp rod bolts
this should net u around 200hp with about 140tq the least
stock gsr/b16 head
stage2 cams
65-68mm tb
440cc injectors
a decent header
b20 block
stock rods
arp rod bolts
The type r heads cost more and the power gain from it is not that much different from a b16 head, only thing you get thats better are the stiffer valve spring and better design light weight intake valves. If you are short on budget, use a b16/gsr head and send it out to someone reputable, telll them your engine specs and just have them hook u up on the right custom valve job profile, thats all you need. They usually run u about 250-300 bucks on the good ****, but its worth every freaken penny.
