Rear Lights
The "small lights" 15 amp fuse keeps going out. I found the driver side front ornimental light was out. A new bulb and fuse and the rear lights worked again for a few days and the fuse went out again. I found the passenger ornimental light was burned out. Again, a change of bulb and fuse and the rear lights worked again for a few days. This time the passenger rear light was burned out and a new bulb and fuse got the ornimental and rear lights worked again. Now the fuse is burned out again and with a new fuse I found that all both ornimental and both rear lights work, at least for a short time. I need to find exactly what is on this circut and where it is routed to find why I keep burning out fuses. I have the original radio and there are no modifications to the wiring system. Thanks.
Sorry, forgot to add. I have a 2005 Odyssey EX. The way I notice the fuse is that when I use the remote unlock the lights do not flash. But this feature does work when I first changed the bulbs/fuse. All other lights (brake, back up. turn) work with no problem.
goldfinger93030
Feb 9, 2009 02:17 PM
DC4R27
Nov 29, 2007 08:16 PM
