95 Honda Accord Automatic Vss
Old Sep 4, 2011 | 07:56 AM
gettin it's Avatar
Default 95 Honda Accord Automatic Vss
Ok, the problem is the D4 light is flashing, and the Mph is not working. I tried to pull the code for the engine and it said it was the Vtec sensor. Ok im running a vtec ecu and the car doesn't have vtec. So i know thats not the problem. Now the code for the d4 it flashes 4 times. Im thinking its the Vss, the speed sensor. Now are the B series and F series compatiable? Can i use a b series vss from a manual trans and put it in a F series Automatic trans? Any other ideas? I tries pulling the plug and making sure its connected also. Nothing, thats why im leaning towards the speed sensor.
Old Sep 4, 2011 | 09:04 PM
slomofo's Avatar
GDD Member
Default Re: 95 Honda Accord Automatic Vss
Some of the b-series sensors will fit in the hole and plug in, but I don't know if the teeth are the same. Accords and Preludes all use the same speed sensor though.
Also, if you're not throwing codes for speed sensor, I would look into testing your gauge cluster before swapping sensors.
Old Sep 6, 2011 | 03:03 AM
gettin it's Avatar
Hmm, i looked at it from the top, and they look the same. I guess id have to try it and see.
KiNGDEE206
Jan 4, 2016 06:33 AM
Sk8NJ91
May 31, 2012 07:18 PM
Rat Rod
Nov 18, 2010 04:02 PM
1player2nv1
Sep 17, 2008 05:08 AM
CodyC142
Feb 3, 2007 02:40 PM
