replaced tie rods, now camber off?
I just replaced the left side inner and outer tie rods on my 94 ls. I have readjusted the toe so that it is fairly close. but when I dirve I notice a vibration that seems to come from the L/F area. I adjusted the toe a bit more and it got better, but did not go away, but when I was looking at the front of the car I noticed that the l/F wheel seems to have some negative camber, looking from the front of the car the L/F wheel looks like \ while the R/F is straight up and down. The car is lowered, but again all 3 other wheels look fine this is the only one that seems to be leaning, my question is while replacing the tie rods could I have done something to cause this? is there any way to adjust this? any help would be appreciatted, thanks.
can post pics if needed.
Anytime suspension, [or related] work is done a wheel alignment should be done.
Around $50-$60 for a 4 wheel alignment and the shop will point out any problems. 94
InTheLBC20
23
Sep 24, 2010 01:44 PM
endlessdreams
Jun 28, 2007 07:04 PM
Boilermaker1
Mar 8, 2004 12:18 PM
