Overheating & Fan Issues
Old Sep 2, 2011 | 10:45 AM
95WhiteTeg's Avatar
Default Overheating & Fan Issues
I have a 95 Integra SE. I can't figure this out. It overheats after sitting for a while because the cooling fan isn't coming on. But both fans do come on when you turn the a/c so the fan works. Coolant level is good and both upper and lower hoses get warm, so I assume the thermostat is working. Any ideas?
Old Sep 2, 2011 | 05:55 PM
fcm's Avatar
fcm
Old Fart
Default Re: Overheating & Fan Issues
ECT switch, fans work when A/C is on because the A/C circuit and rad fan control module, [misnomer, should be condensor fan control module] turns bot rad and condensor fan on when A/C is on, the ECT switch turns on the rad fan only.
Unplug the ECT switch and jump the 2 leads, [green and black] in the plug, [ign. switch must be on] if rad fan turns on replace ECT switch, if not, check the green lead between ECT switch and the rad fan relay. 94
f15Civic
Mar 9, 2017 05:45 AM
Natural Aspirations
Engine Management and Tuning
18
Mar 1, 2011 12:48 PM
kai-chun
12
Sep 8, 2006 03:20 PM
ATS*Mark
Dec 9, 2003 11:08 PM
