Very tocuhy gas pedal problem
Old Sep 1, 2011 | 07:27 PM
bigred850's Avatar
Default Very tocuhy gas pedal problem
I have had a automechanic attempt to fix my seriously touchy gas pedal but wasn't able to fix it because he said that something about the throttle was electronicly controlled by ECU and it would have to be brought to a proper tuner. I do have an autronic SMC standalone computer managing my setup.
Does anybody know of a very simple setting I could tweak or turn on or off if I was to connect my laptop to the ECU so the gas pedal acts normal??
I don't have access to a dyno at this point in time but I will in the future when I get the car properly tuned by a pro. Also, why does my motor idle between 2-3k RPM? And when I tap the gas pedal ever so gently in neutral it will go back to a normal 1k idle. It does not start up at a high idle but it does idle high after the gas pedal is applied steadily and let go slowly.
It sucks having these symptoms because I can't control my car very well and have to burn up my tires from a dead stop just so I can get going in first.
Old Sep 2, 2011 | 11:11 AM
sc_at_QuaifeUS's Avatar
Default Re: Very tocuhy gas pedal problem
Autronic isn't going to throw OBD codes...
Unfortunately, the only guy I know of that uses Autronic is Enzo. enzo-racing.com
My bet is that you need an accel enrichment / threshold adjustment, but I don't know where to tell you to look for that in Autronic. Or, was the TPS removed and reinstalled (somehow re-indexed)?
Old Sep 2, 2011 | 12:08 PM
welfarepc's Avatar
what car? what size throttle body?
the bigger the TB the more air its going to let in at small angles.
Old Sep 2, 2011 | 01:17 PM
bigred850's Avatar
Thank you and your repsonse has been noted
I have a 80cc Mustang throttle body on a full GSR motor. Here is my setup to the best of my knowledge...
Rebuilt B18C engine with only 3000 miles
Newly rebuilt transmission with quaife
Ported and extrude honed head
AEM cam gears
Darton sleeved block
JE pistons
Oliver rods
Type R crank
Custom external oil pump system
belt driven Proflo pump with external Moroso custom oil pan and external pickup
underdrive pulley
Cometic head gasket
ARP head studs
Jun retainers and springs
500 HP axles
Tilton multidisc clutch and flywheel
T3 turbo, 4 inch inlet, 3 inch band clamp downpipe
4 inch exhaust and Borla Supersport stainless muffler
JG exhaust manifold with Tial wastegate
Autronic SMC standalone
MSD 7al ignition
Pro Blaster 7 series coil
MSD cap
Nology plug wires
STR intake manifold
STR fuel rail
RC 1000 cc injectors
Full stainless lines
80 cc Mustang throttle body
Spearco intercooler with 3 inch piping
high pressure clamps
C&R aluminum radiator
Spal slimline fan
Old Sep 2, 2011 | 01:47 PM
FlewByU352's Avatar
I love a touchy gas pedal, hard to drive if you are tired because a 1/4" pedal travel and you are revving to 3,000RPM lol. Its an on off switch with no play.
Old Sep 2, 2011 | 02:03 PM
bigred850's Avatar
That would be a very accurate description of what I have going on. But, how can I make the gas pedal normal again?
Old Sep 4, 2011 | 11:06 AM
welfarepc's Avatar
put on a smaller throttle body so its doesnt flow so much air at low throttle angles.
sorry to tell ya.
Old Sep 22, 2011 | 01:25 PM
lugnuts's Avatar
The Autronic SMC ecu definitely does *NOT* have an electronically controlled gas pedal.
The newer Autronic SM4 ecu does have this function.
I can help you if you are still having issues. Take a picture of your ecu and email it t me or post.
Old Sep 23, 2011 | 08:07 PM
bigred850's Avatar
PMed you
Old Sep 24, 2011 | 03:31 PM
bigred850's Avatar
Here is a snapshot of my ECU.
sumuno
Aug 1, 2014 04:30 AM
vi3tromanc3r
Aug 30, 2008 12:10 AM
dgn1978
Jul 13, 2003 02:44 PM
jdm169
Feb 9, 2003 07:24 AM
