Cost for a DIY paint job
Old Sep 1, 2011 | 04:05 PM
VTEC-DA's Avatar
Default Cost for a DIY paint job
Havent posted here in a while but I am about to pick up a civic coupe for dirt cheap and plan on painting it myself. Im looking for a ballpark price on how much other people have spent on painting there own cars. Due to my current living situation, I will be constructing some kind of tent in the backyard and doing this on the cheap as far as those materials go and spending a little extra on the filler, paint etc. Ive done this before and it came out really well but it was like 8 years ago when I knew a ton of people in the scene and got hookups on pretty much everything I used so I guess what I am looking for is others who have gone this route and what theyve spent.
Old Sep 1, 2011 | 05:27 PM
(. )( .)'s Avatar
Default Re: Cost for a DIY paint job
compressor $400+
1 gal automotive paint $300+
"ok" paint gun set $80+
Other supplies $100+
^ that doesn't include supplies for body work
Old Sep 1, 2011 | 05:51 PM
gorillafart's Avatar
im in the process of respraying an evo8 in the garage.
so far for materials alone its been
approx $150 in various DA sand paper grits, masking tape, scotch pads,
approx $1300 in automotive paint (1gallon of paint, 1 gallon of primer, 1 gallon of clearcoat), and their hardeners & reducers, 1 gallon surface cleaner, 1 gallon solvent (for gun cleaning), surface wipes, tack cloth, masking paper, mixing sticks and measuring cups
of course theres cheaper alternatives. but this is what im doing.
Old Sep 1, 2011 | 05:54 PM
kaiba's Avatar
$50 roller paint job.
Old Sep 2, 2011 | 10:19 AM
VTEC-DA's Avatar
I've got the compressor and gun already. The $1300 for supplies, is that on the high end or can I expect to pay that much for middle of the road quality paint etc. This is going to be far from a show car but at the sme time, I don't want it to look like ****.
Old Sep 2, 2011 | 01:35 PM
Builda'Teg_92's Avatar
i think thats on the high side if i get your question....what brand paint will you be going with?
Old Sep 2, 2011 | 02:44 PM
the amount im spending on paint, isnt even custom paint. im just doing an OEM respray... by an OEM approved manufacture.... but it is a little on the higher end.. its definitely more for warranty type of work, and finish. not to say you cant get that out of a lower priced brand. but im going for fool proof
now thers NO SUCH THING AS OEM PAINT... but there are brands approved by the manufacture that they like
my paint i can expect to last the life of the car, as if it was never resprayed at all.
i live by the motto, u will get what you pay for... so spend accordingly to what you want from your finished project and product
buildateg... im using Sherwin williams AWX and their p27 primer, and their CC921 clearcoat....
thats not even as expensive as the paint i wanted to use, which was Akzo Nobel
Old Sep 3, 2011 | 07:16 AM
(. )( .)'s Avatar
he can do it less than $50..
1 gal paint $10
1 gal mineral spirit $5
1 roller $5
sand paper $10
masking tape ¢75
and 1 hour later..professionally painted car
Old Sep 3, 2011 | 08:51 AM
CivicMike's Avatar
$600 ish
http://www.e90post.com/forums/showthread.php?t=376442
Old Sep 9, 2011 | 09:10 AM
joeshmo's Avatar
Have you considered renting a booth will real ventilation and lighting and filtering? If I were to paint in a tent, I wouldn't use real high end stuff as your paint job will only be as good as your prep and your environment. I had good results using cheaper single stage and SPI universal clear. SPI is 200$ per 2 sprayable gallons, my base was 80 dollars and my primer surfacer was 120$ for the gallon and a half. Throw in another 160 for epoxy and some stripper.
Or you could go with kirker. Kits start at 217 for primer, color and economy clear. It'll be good enough for a tent job.
Old Sep 9, 2011 | 10:45 AM
BigDaddyRich's Avatar
Hmmm.... Already have a compressor in my garage.
$150 for DA, sandpaper, body filler, primer and various sandpapers.
$120 for 4 harbor freight HVLP guns and regulators. (base, clear, primer, small detail)
$320 for Paint, reducer, hardener etc... and related supplies.
$50 for masking tape, wrapping paper, drop cloths and other misc prep things...
Old Sep 9, 2011 | 02:27 PM
joeshmo's Avatar
Why spend 120$ on HF guns if you could get a decent Astro gun for that price? What are the specs on your compressor?
Your prices seem pretty close to spot on for using lower end paints which is what I would advise with a "booth" like you have. Except one thing: use REAL wax sided masking paper. Wrapping paper will not work, nor will newspapers and you'll "unwrap" the car to overspray on every window/piece of trim.
GoLowDrew
Paint and Body
Jun 23, 2013 10:22 AM
Korean Zombie
Paint and Body
23
Oct 13, 2011 12:01 PM
ijust1agame
Oct 26, 2007 10:34 PM
The Alchemist...
Nov 16, 2003 11:04 AM
DanielLaruso
Sep 22, 2003 11:36 AM
