FS: 2011 Allmotor Shootout funding sale (k-series and b-series)
trying to buy a few things for my racecar and so need cash funding for the Oct 1st allmotor shootout lol...bunch of stuff for sale:
K24 4-1 race header with HyTech meg 3" collector...$1100neg
K24 SSR 4-2-1 header 2.5" collector...$950neg
RSX Ebay header with cat delete brand new...$375neg
Custom Endyn rollerwave B18A/B/B20B/Z 0.250" crower long rods 5.644" with accompanying 86mm bore pistons abotu 14.5+:1 compression....8 rods and 6 pistons...$600
OBX K20A/K24A 52mm ITBs new...$500
LS 86.5mmx95mm stroker longblock with ported head, ported victor X intake manifold with 74mm thr body, JDM ITR copy header, single disc clutch, lightened flywheel and hydro B16A tranny, obd1 engine harness, started/alternator, etc...$3500
86mm LS sleeved block (needs honing) with LS crank with Arias 13:1 86mm pistons (unassembled) .....$600
Custom huge plenum K-series intake manifold with 75mm opening t/b flange for GM/Ford/Infiniti, 80mm Q45 t/b...$350
84.5mm used 13:1 compression pistons for use with 92mm crank and LS .137 longrod for b-series...$250
the pistons were on this motor in the thread:
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/update-92mm-crank-motor-endyn-parts-buildup-1342744/
82mm JE turbo pistons....$200
86mm new 14:1 compression coated Endyn rollerwave/Wiseco pistons for use with 89mm LS crank and .137 (5.531) longrod for b-series...$400
89mm K24 used Wiseco pistons 13.7:1 compression scratched up at the top but worked fine (used them like that with no problems)...the chips etc were from broken sparkplug tip...$250
stock sleeved 87.5mm bore K24 longblock with custom IPS/JE pistons, custom rods, new ACL race bearings, ported PRB head, IPS K10 cams, no manifold, no oilpump, bare longblock, made 320+whp with IPS intake manifold....$4500
bare F20C head from S2000, has all but 1 intake valve...$400
complete PRB K20A2 head with cams, rockers, valvecover, etc...$700neg
ported 1st gen B16A head bare (no valves, seals, springs, retainers) but has all rockers and cam caps, etc....$450
email me at gbrtuning@aol.com or pm me here...will gather pics etc and post up asap.
looking for EXOSpeed EG 3 piece frontend, CF hood for EG coupe/hatch...must be local...if you're a good auto painter, hit me up too.
thanks
thanks
bump...
sent you info on the stroker longblock...
head ported by portflow
endyn bumpstix cams w/adj cam gears and upgraded valvesprings/retainers
about 14.5:1 compression, 86.5mm bore and 95mm stroke yielding 2.33liter motor
motor never dyno'd, ran it at track with street tires spinning the whole way and got a 11.9 @ 119mph with a 2.4 60'
CHEETAH
Sep 27, 2011 06:43 AM
Steven.
Mid-Atlantic (Sales)
Jul 2, 2008 12:52 PM
